  Wankel i teorien !
(permalink) kitcarlasse Member
Wankel motoren må siges at være så simpel så den er genial. Dog er alt andet end selve blokke og rotorene temlig kompliceret !
Wankel motorene er lavet med en enkelt og to rotorer fra fabrikken ! Med en undtagelse er Mazda's Cosmoz motor der har tre rotorer !
Faldt lige over en firmahjemmeside der var ret interessant.
http://www.hurley-engineering.ltd.uk/
Har specialiceret sig i at renovere og bygge speciale wankel motorer. De siger at da wankel motoren er bygget om som en lagkage kan man i princippet fortsætte til det uendelige ! De tilbyder således både en 3 og en 4 rotors wankel motor for dem som vil investere :lol: Sidstnævnte har 900 hk !!!!!
Sådan var det da jeg så for sjov regned lidt på en 12 rotors wankel motor !
12 stk rotorer
24 stk tændrør
12 stk tændspoler
6 strømfordeler dæksler
12 eller 6 turbo'er
7,84 liter
ca 600 kg (ren motorvægt)
36 antændninger pr 360° motorrotation (en V8 motor 4 antændinger )
ca 3500 hk
max ca 13500 omdr pr min.
Og i teorien ku' man fortsætte !!!!
kitcarlasse
The world's quickest 12A rotary over the 1/4 mile is this almost certainly this car.
Owned by Boris from Delirium Racing in Puerto Rico, this Datsun 1200 is powered by a 12A turbo. It's best time is 8.27 @ 160 mph!
This is quite an achievement as there are many 13B and 20B powered cars that are 2 or 3 seconds slower than this.
Here's what Boris said about the car (minor edit by me):
The car is a 1972 Datsun 1200 full tube mild steel chassis. It has the 12A with an Innovative turbo and wastegate, a Tial blowoff valve a Greddy intercooler with 4 1100cc injectors. The throttle body is custom made and has a Racing Beat intake. It runs the stock distributor with MSD 6AL boxes and coils. The fuel injection system is a Haltech F-9 programmed by Jorge "Oso" Juarbe. The engine has a port job done by Jose Burgos.
We use VP Race fuel with a Aeromotive fuel pump and regulator. We use a Mc Leod clutch with a G-Force 5 speed clutchless tranny. This hooks up to a 9" Ford rearend with 4.56 gears. The tires used are 29X12 Goodyear slicks.
(permalink) tagsnket Member
[b:1d7d8b9dba][size=24:1d7d8b9dba]et TOTALT GODT INDSLAG... der er simpelthen SINDSYGT hvad der kan komme ud af så "LIDT" :-)[/size:1d7d8b9dba][/b:1d7d8b9dba][color=red:1d7d8b9dba] [/color:1d7d8b9dba]
(permalink) SoLow Member
JA... Og helt vildt brugbart i en VW... NOT :?
[quote:36eabeca11="SoLow"]JA... Og helt vildt brugbart i en VW... NOT :?[/quote:36eabeca11]
Sure Martin :roll: :p
~Mette
Er bare ved at være træt af Wankel og Vandkølet Alfa information på forsiden af "VW"nettet !! :?
(permalink) Duus Member
Hver sin smag... wankel og alfa motorer er ikke helt uinteressante for de kan jo godt komme i en gammel vw...
Så absolut kan de det... Og lad os så komme med en opfordring til alle dem med 3500 HK Wankelmotorer i T1 eller Ghia komme frem :wink:
Har intet imod at blande ting sammen så længe det er brugbart inden for vores hobby, men mener bare at man måske skulle holde det inden for de grænser som er relevante, ellers kan vi allesammen begynde at lave indlæg med info om de 35 andre slags motorer som også kan sidde på en VW gearkasse, og hvor er VW emnet så henne :?:
Mener i bund og grund at vi skal holde denne side VW baseret, og så lade de tusindvis af andre fora´s på nettet handle om det andet !!
Martin
Syntes bare det er lidt synd at ingen har mod på at prøve noget nyt !
:roll:
Jeg mener jeg enganng har læst at et ægte Gearhead tænder på alt med hjul og motor...
Jeg kan godt forstå dit synspunkt Solow, men jeg synes ikke det er virkelighedsfjent at montere en alfa boxer i en vw. Jeg vil ligefrem sige at det er et gunstigt alternativ for nogle.
Det kan jo være at nogen synes at det er fedt at man kan få mange heste til små penge, og er ligeglade med originaliteten.
Hvis siden kun var baseret på vw, ville jeg f.eks. ikke vide at man kunne lægge andet en luftkølede vw i en type 1.
Duus
Ja... men nu er jeg heller ikke Gearhead... Må ikk være med (min bil skal være blank) :wink: :wink:
Men kan godt se det fra din side, og har heller intet imod andre motorer.. men info om motorer på 3500 hk, finder jeg ikke skide relevant.. jeg kan da også finde sider med 34000 hk´s jetmotorer, men igen ikke skide relevant for den daglige VW..
Men okay... lad os alle skrive om ting som kan sidde på en VW, og lad os så se hvor fedt i syntes at vores lille forum bliver :?
(permalink) REN Member
Du snakker og snakker..
Gu har det da relevans...
http://www.ronpatrickstuff.com/
R
Tlf: 61713873
(permalink) Biffo Member
Det er da et ok indlæg - især når det ses i forhold med andre indlæg her på sitet.
( f.eks. "Jydekrog" )
:roll:
Hej Lasse.
Jeg tror personligt.. at nogen måske mister motivationen til at prøve nyt, når andre skriver eller fortæller dem, at det projekt de er i gang med, må de endeligt ikke skrive om på internettet.. for told og skat følger med og notere hver en møtrik der skrives om......
Det er noget vås..efter min mening..
Jeg tror ikke at Skat har resurcer til det ?!? og hvorfor skulle de..
Jeg syntes det er lidt paranoid at se sådan på det.. med mindre man prøver på at skjule noget..
Det er P.... dyrt at lave kitcar.. turbo på sin bil.. anden motor eller andre konstruktive ændringer.. det kan man ikke lave om på, hvis det skal være lovligt..
Jeg tror personligt at der kommer flere til for at prøve noget nyt.. som du efterlyser.. hvis der bliver skrevet åbent om de projekter der allerede findes..
Skallerup
Vejle.
Keep your dream alive.!!
(permalink) mSTIGAARD Member
øhmmm har i set dato'en fro dette indlæg?!
e - mails : mads@stigaard
Mobil : 40327555
Næ... :)
Men jeg mener det samme uanset dato.. :)
Mvh.
Skallerup
Vejle.
(permalink) thogaa Member
Det er skam helt vildt brugbart i en VW:
40818888 gaardsoe.com
Bay window hippie bus owner
Thogaa:
Det er da super svedigt med den wankel. Hvor har du fundet de billeder? Er der mere info om den bil og hvordan det er lavet og hvormeget den yder?
warp skrev:
Thogaa:
Jup. Her: http://www.geocities.com/zenjoe/vw.html :)
(permalink) Vinge Member
Lige som et dansk eksempel, kan den superfede sorte T1'er der er i denne måneds udgave af Vmax nævnes. Han er da vist sluppet rimeligt godt fra montering af en Wankel-motor.
Der er vist en anden tråd herinde hvor det diskuteres hvorvidt bilen er fed eller klam, men lad det nu ligge.
Mvwh. Vinge
1303 Roadster
http://www.bilgalleri.dk/html/gal_visbil.asp?ID=61309&ipc=196272
Fede billeder Thogaa..!!
Mvh.
hvor får man fat i sådan en?
bruger den ikke sygt meget benzin, for at opnå den samme effekt?
Hørte lige et rygte fra Eg om at den sorte med wankel fra Vmax skulle ha' 270 hk ...og den er vel at mærke droslet ned til 270 for at gearkassen kan holde.
...SWEET!!
føj da.
den sorte hvad?
Andreas4321:
Den sorte type 1 fra 1973 som er i Vmax i denne måned ...eller måske var det sidste måned.
Er der nogen der ved hvordan det er med syn og wankel motor? Det jeg tænker på er den regl om at man ikke må smide en motor i sin bil som er mere end 20% større i slagvolume. Man skulle kunne få 180 hk ud at en std. 1200 cc wankel i følge hvad der står på den side som thogaa har linket til højere oppe i denne tråd. Det er da en ret "snigeren" måde at få mange heste i sin type 1 uden at skulle ud i noget med ekstra afgift og alt det der. :-)
...men er det lovligt? (Frank du må ha' en mening om dette som synsmand)
Jeg synes det er helt vildt fedt at se et gammelt indlæg blive vækket til live igen. Beviser bare at der rent faktisk er nogen der ved hvordan man får mest viden og alt andet ud af et forum som VWnettet.
Fedt at se et par biler som kører med Wankel motorer. Det har jeg personligt ikke set i en VW før.
~Mette
