  ventilerede bremser...
(permalink) rumraketpiloten Member
taget direkte fra http://www.customspeedparts.com
CSP Vented Front Disc Brake 5-205
The famous CSP 5x205 front disc brakes are now available as vented! The upgraded system has been redesigned with a 278mm internally vented rotor and specially enlarged calipers. No spindle modifications are required and they are available for the following vehicles:
Beetle and Karmann Ghia with link pin suspension
Beetle and Karmann Ghia with ball joint suspension
Thing (Type-181)
Bus 1950-1970
Type-3
Porsche 356A and 356B
and all Buggies, KitCars and Replicas with Beetle link pin or ball joint suspension
The kit contains all parts to convert the car to a 5x205 vented front disc brake system. Only the master cylinder needs to purchased separately in order to match the application.
ny pris 1149 euro...
kittet har aldrig været monteret, ligger stadig i original indpakning... passer til type 1 fra '66 og '67
pris 6500,-
to skt. spax støddæmpere også helt nye... 750,-
samlet pris 7000,-
+ evt. forsendelse
