  S:Csp type3 phyton udstødning i rustfri stål
Helt ny type 3 udstødning komplet med csp's egen stainless steel jtubes
..det er 38mm udstødning jeg har
The CSP PYTHON Exhaust System is now also available for Type-3's. This exhaust system for large capacity, high performance engines that still allowed the use of heat exchangers is made for street applications. It features equal length header pipes and a precisely manufactured collector with matching firing order for maximum gas velocity, which improve the torque curve all the way up to peak horsepower. The stainless steel absorption silencer, specially manufactured for CSP Products, provides the system with a dull, thudding, sporting sound.To match your engine specifications three diameters are available - 38mm, 42mm, 45mm (outer diameters)To protect the air intake grommet of the cooling system the silencer is equipped with an aluminium heat shield at the top.This stainless steel exhaust fits all Type-3'sHeader made of stainless steel 1.4307Silencer made of polished stainless steel 1.4301to be optional used with heat exchangersCan be supplied in 38mm, 42mm or 45 mm diametersvarious cone diameter insertsEqual length header pipesSolid laser-cut flangesaluminium heat shield on top of muffler
Pris 5500kr og det er meget billigt for denne udstødning
26707331
