  Solgt.
(permalink) kim_engrob Member
5 stk. Originale Bug Me videoer sælges.
Jeg har betalt 950,- kr inkl. porto for dem for 1 år siden. De er i perfekt stand, da jeg kun har set dem 1 gang.
Som nybegynder har jeg fået rigtig meget ud af at se dem, da de er meget grundige.
Jeg kan kontaktes på 2258 7585
Jeg har købt dem på http://www.bugmevideo.com/
Volume 1 - General Maintenance:
-Raise the car
-Secure on stands
-Drain the oil
-Clean the oil screen
-Examine & Replace the spark plugs
-Check the compression
-Replace the points & condenser
-Examine the vacuum advance
-Identify your distributor
-Set your timing
-Solve common carburetor problems
-Adjust the valves
-Replace and adjust the fan belt
-Adjust the clutch
-Adjust the Brakes
Running time: 1 hour
Volume 2 - Pull Motor & Clutch Service
-Pull the engine
-Remove and replace the flywheel and clutch
-Identify your flywheel and clutch type
-Examine the clutch disk and pressure plate
-Replace the clutch release bearing & arm
-Replace the crank seal
-Replace the rear transmission mounts
-Replace the clutch cable
-6v to 12v - starter and flywheel changes
-Put the engine back into the car
Volume #2 will show you everything you need to know to take the fear out of pulling your motor!
Volume 3 - Complete Engine Rebuild
Completely rebuild a type I engine!
Volume 3 is a complete engine rebuild video, it covers the 1600 dual port, 1500, and 40 hp motors and all the important differences.
Includes:
-Tear down
-Inspection
-Reassembly
If you have ever been hesitant to tackle something as big as an engine rebuild, this video will give you all the information and confidence you need, you can rebuild your engine, let us show you how!
Running time: 2 hours 38 min.
Volume 4 - Brakes
-Replace the brake shoes
-Replace the wheel cylinders
-Replace the brake lines
-Replace the master cylinder
-Replace the drum
-Replace the disk and pads (disk brakes)
-Replace & adjust the emergency brake cable
-Replace the front wheel bearings & seals
Running time: 1 hour 45 min.
Volume 5 - Transmission Replacement
-Replace the transmission (I.R.S & swing axle)
-Replace the axles (I.R.S & swing axle)
-Remove and replace the shift housing
-Replace the C.V. Joints
-Replace the rear axle bearing & grease seals
There are three different axle and tube set-ups in the old types, we show you how to change the axles to suit your car.
