  Søger links
(permalink) BRB Member
Søger links til leverandør af wbx stroker krumtappe.
På forhånd tak
Bjarne
(permalink) vwmorten VW-Guru
http://www.demellocranks.com
fik dette svar fra dem for noget tid siden..:
Sir,
Yes we do build a stroker crankshaft for that motor. We stroke , heattreat , balance,
micropolish etc.
We need a 2.1 crankshaft to go up to 82 and 84mm stroke. We will build up to 78mm on the
other core. As far as the forging goes on the cranks they are a decent forging . It is not
a cast cranshaft or we could not stroke it, plus it would not last it would break. The
cost for a 82mm c.w crankshaft is $450. The 78mm c.w is $425 if you have any question
please either e-mail or call at (714) 898-7405.
Thank you, Chris, Demello Machine
26150707
