  Web Cam Contest - Motor Kaboom
What is wrong with the my motor contest !
You can win a web cam at no charge, contest is today only, results in a week or two. I will even pay the postage to you. Now the story and contest.
Last night finished the garage for the 57 oval, parked it and decided to celebrate, so we cranked up the 56 Oval and decided a tur to Tivoli sounded good. We got as far as Ring Vej 4 i Ballerup and the motor was went Klunk Klunk, bop bop boom !! Hmmm, drove over to the side, seemed like muffler came loose, but cound not see without a light, drove farther, and klunkitie klunkite klunk, klunk and a few more metal sounding sounds. Motor still ran, no oil light, no lose in power. So we parked the car at a friends house and do not know what is wrong yet.
But now we see oil leaking from the one side of the motor. YUCK !
So before we check out the car, you can have 1 guess each what you think went wrong with the motor and in case of a tie breaker, you can also guess how much it will cost me to have repaired.
Answers like, what went wrong, that are not accepted are below ! ;.)
An american was driving,
You had your wife with,
It is not a Rat,
You talked about getting FDM in the car the same night,
You drove it in the winter,
You were listening to Steppenwolf MP3 at the time,
etc.
So lets see who is the best to guess what went wrong with my VW.
P.S. The motor is a 1.6 motor, nothing else special with it.
P.S. Only registered users are considered for the contest, gæsts are not taken seriously.
Hilsen, Coty the unlucky bastard.
You "dropped" a valve. Most likely an exh.and on cylinder 3
T.
(permalink) hottentot Member
Hi Coty
I had a similar experience, the first time I took my 68 (VW) for a ride.
I'm not sure if a Dane and a Americam will give sounds the same "name"
but the sound that came from my engine was.
Weee Weeeee Weeeeee Weeeeeee Weeeeeeee (Like a Turbine)
followed by
Cloenckkk Cloenckkk Cloenckkk Cloenckkk.
The problem......
Very elementary my dear Watson..
The "Aircoolingfanhouserightsidemountingscrews" was missing
and the "Aircoolingfanhouseleftsidemountingscrews" was loose.
Therefore the "Aircoolingfanhouse" was jumping around making strange
sounds.
Hope you will find the failure.
Med venlig hilsen
Peter "Hottentot"
(permalink) ploug Member
damn coty - i'm sorry to hear my former baby blew up on you
when you find out what the cause is drop my a line
my guess is farmer is right, i had a 66 bug that did just that, the differens being the 66 wouldn't turn over - and the spark plug where "pushed" out
I payed 5000,- to have the 66 bug repaiered after that incident ( and i had the clutch replaced as well )
mobil nr: 22-26-03-12
(permalink) Fastoldvw Member
My guess is a fåkd rod bearing...
Been there..
Yep, I think Farmer is close, but we will not know the problem until later this week. But then again, it could of been the rod bearing. We will see soon enough.
(permalink) cardude Member
how is it coming along.
Not good, Xmas seems to be getting in the way of things, and family seems to be wanting more time ! ;-)
And my expert that is going to help with the motor is busy until the first week of Jan. So then we will know the winner, and the web cams are in a safe place , ready to give out ! ;-)
Well Farmer, your the lucky winner, you hit the spot right on !!! And the correct cylinder, do you have ESP ???? hmmm
Well let me get my act together and send you a picture of the webcams and you can select which one, or do you need anything else let me know via email.
We just got electricity after 3 days, so give me a few days to email picture to you.
Congrats, Coty
(permalink) SorenJ Member
Sådan Farmer!
Det store spørgsmål er...
Han du fundet ud af om motoren er til at lave igen eller om den er junk?
Ring: 28118212
It will be up and running again this week, thanks to Dennis.
Hopefully by torsdag ! ( Hint in case he is reading ) :-)
Coty
cool.
Jeg glæder mig til at se din 56'ere
Ring: 28118212
[quote:d4135faa92="YankieBar"]Well Farmer, your the lucky winner, you hit the spot right on !!! And the correct cylinder, do you have ESP ???? hmmm
Congrats, Coty[/quote:d4135faa92]
ESP ! ? Naah, just seen a lot of those types of failiures. good thing the rest of the engine was salvage able.
Take your time. I´m in no hurry.
Glad you finally got electricity
T.
(permalink) dRjENSEN Member
First of all im sorry to hear about that engine of yours coty, but still.. guess it could have been alot worse though :wink:
second..
[quote:4141adcd54="Farmer"]You "dropped" a valve. Most likely an exh.and on cylinder 3
T.[/quote:4141adcd54]
Hvorfor sker det egentligt? opslidt motor? eller ligger der noget andet bag!?
Jeg lavede samme nummer med min 1500 i sommers.. Eneste forskel er at min ventil røg igennem stemplet og videre ind i kværnen, så stumperne fik en tur rundt i hele manegen..! :roll:
Lige til jerncontaineren.. Well ikke helt, det ene topstykke kunne da bruges.. :x
Men sådan går det jo. Det er vel metaltræthed der gør det tror jeg. Min motor var sku den originale til min bus, så den var 40 år gammel og havde garanteret rundet millionen (eller to), da den brugte de første 10 år af sit liv som taxa..!
Nå, Det var så mig deroppe. :roll:
Takker for den fine forklaring! :D
OK, the real truth of what happened, This girl was driving her Citroen and drove right in front of me, she was chatting on a mobil and did not see me, can you believe that !! No control over her car, what a Bitxxx
It made me drop my burger, which spilled the cola setting on the floor, which hit the wife's legs while she was giving me a neck massage, then my cigarette dropped between my legs, then spread my legs to get it, accidently popped the Gene Berg into 2nd gear going 180 kph, and that is when it happened. Dont know why but it did ! heheheh
The real truth, shit happens !
[quote:ee911354c8="YankieBar"]OK, the real truth of what happened, This girl was driving her Citroen and drove right in front of me, she was chatting on a mobil and did not see me, can you believe that !! No control over her car, what a Bitxxx
The real truth, shit happens ![/quote:ee911354c8]
Real good story -just too bad you don't smoke :wink:
~Mette
[quote:32b47b9712="YankieBar"]OK, the real truth of what happened, This girl was driving her Citroen and drove right in front of me, she was chatting on a mobil and did not see me, can you believe that !! No control over her car, what a Bitxxx
The real truth, shit happens ![/quote:32b47b9712]
hahaha Coty. From that wild imagination of yours I´d suspect that cigarette of being a huge joint :D :D
Huffin´and puffin´'
Kasper
(permalink) munken Member
Hmm....that was me - forgot to log in.....
CHeers
Kasper
Let it flow - let yourself go
(permalink) bugservice Member
sådan så det ud da jeg skilte den ad ventil var lige vent om og sat sig i stemplet, lidt heldigt så det bare på med et sæt 1600cc + et sæt 041topstykker så køre du igen Coty
MVH Dennis
http://www.bugservice.dk
Dennis, dont want you to get your fingers dirty, why dont you just install that new 2.3 motor that is on the floor insteadin picture 2. I am just thinking of you ! hehehe
så tror jeg der er en cab ejer der bliver ked at det
Dennis
