  vinteropbevaring af batteri
(permalink) André Member
nu når man skal til at vinteropbevare sin vw er det så ikke det bedste for batteriet at pille det ud og tage det ind i ens hus i varmen? eller hvad gør i ? og skal men sætte en lader på i ny og næ?
(permalink) KimHH Member
Ja til det hele...
I am not sure I agree, why do they say keep your batteries in the frigerator ?
If your not starting your bug in the winter time, then does it matter.
In the spring, when its warm, should start with no problem.
But old battery, hard winter, might be problem.
Winter hints, change your oil now, so you dont have old oil sitting in the motor all winter, might have deposits or moister in it.
Also dont start the motor in the winter, just use a wrench and turn the motor, that helps lube the cylinders without building up dampness in the motor.
Leave the window a little cracked so you dont build up dampness in the interior area. That is if you have the car parked inside ! ;-)
Push the car some times so you dont get flat spots on the dæk. Or the first drive in the spring is bump bump bump ! ;-)
yes i will change the oil tomorrow, i have the castrol classic 30 oil from http://www.vantage.dk and a new oliesi and dæksel, i was aware of your hints but was a little unsure what to do with the battery.
