  009 fordelere stifteløse.
(permalink) syd-import Norge Member
Hei. Har noen 009 fordelere med stifteløs brytersystem. Har solgt mange i Norge og har fått mange gode tilbakemeldinger. se salgsannonse i Norge: http://forum.vw2you.com/cgi-bin/UltraBoard.cgi?action=Read&BID=8&TID=51160&SID=2763118
Disse slges for 600 dk (650 nok). Frakten til danmark er 140 dk (150 nok)
Dette skriver cip1 om fordelerene:
This is the newest version of a classic VW performance 009 mechanical advance distributor with built-in factory hi output electronic ignition module. Re-tooled and 100% brand new. Made to the finest OE German quality standards, this replacement "009" mechanical advance distributor is much better quality then the Brazilian made Bosch 009 distributor which is now in very short supply. Save money and get the best 009 distributor on the market. This style of distributor has been used for over 30 years in all sorts of stock and Hi-performance applications. This is the easiest distributor solution for any aftermarket carburetor set up, as it does not reply on vacuum for its operation. This distributor has 22 degrees advance built in and reaches complete advance by 2600 RPM, perfect for most 16-2300cc Beetle style engines.
Interessert: Mail til: Formann@agdervwklubb.com
