  Ebay motorer
(permalink) schakenda Member
hej Motorguru'er
jeg har kigget på en Ebaysælger fra USA der sælger både færdige og Longblock motorer
er disse noget værd, eller er det noget man skal holde sig fra ?
prisen ligger på 2050.-$ + 150$ i transport
You are bidding on a 1915 dual port complete motor refurbished motor. SOLD OUT RIGHT no core needed 30 day limited warranty....
They come your choice of the following colors:...
RED, BLUE, ORANGE, BLACK, YELLOW, GREEN and PURPLE....
all come with BRAND NEW chrome shrouds
BRAND NEW chrome dual port tin
BRAND NEW gen backing plate
Rebuilt generator,
BRAND NEW generator strap
Stock Carburetor
BRAND NEW silicone rubber intake boots and clamps
BRAND NEW color to match air-cleaner and crank case breather,
BRAND NEW 009 dist
BRAND NEW colored spark plug wires and new spark plugs
BRAND NEW spark plug separators
BRAND NEW degree pulley and belt with new chrome gen/alt pulley
BRAND NEW spark plugs
BRAND NEW Fuel Pump
BRAND New Oil sending unit
Reconditioned longblock has:
rebuilt head with new valves
New Valve covers chrome
new 94mm piston cylinder and rings
new push rod tubes
Reconditioned case with case savors
reconditioned 8 doweled flywheel
polished 8 doweled crank
new main, rod and cam bearings
new double lipid rear seal and all new gaskets
balanced reconditioned rods
stock cam and lifters
reconditioned oil pump
ALL Motors are Tested before leaving the shop
the HP is approximately 90hp
the motors are built to order and take an approximate 3 weeks to build after payment has been received
Du kan få den i LILLA. Waow!
Prøv lige og L
Prøv lige og L
det lyder som en fair pris og der er skam ikke noget galt med at bruge brugte dele så længe de er i orden.
Det virker meget fair og der er penge at sparre iforhold til priserne herhjemme f.eks.
jeg vill absolut ikke tøve med at købe en motor og sparre kassen så længe han har positiv feedback.
(permalink) klokmose Member
det bedste, er dog stadig at du kan faa den lilla. Men husk foresten at ligge og afgifter til prisen, ogsaa fragtens. og for pokker, det er langt borte, hvis man vil klage....
det er jo grunden til at jeg poster det her, det er jo at få din/jeres mening om det - ikke om at "jeg kan få den i LILLA".
jeg er ny i VW verden, så hvorfor ikke spørge dem der ved noget om det (jer) istedet for at brænde nallerne.
VH jesper
(permalink) kanalt Member
Prøv lige og L
Kan alt det umulige tager tid
http://www.Buggyteamsyd.dk
Sønderborg
den kan da umuligt fås billigere i danmark, med den $$ kurs kan det vist ikke engang betale sig at kigge efter tilsvarrende i danmark !
Det er sgu da ligegyldigt om den er lila rød eller blå bare skidtet virker
kanalt skrev:
Prøv lige og L
Google er jo en genial opfindelse..... nedenstående + div link i tråden giver vist rigeligt info og læsestof om den pågældende ebay sælger:
http://www.thesamba.com/vw/forum/viewtopic.php?t=354
(permalink) BuggyBoy Member
Damn, det lyder da ikke for godt det nogen af de andre har oplevet :S
