  S:1914 125HK
(permalink) mortengram Member
solgt
Den har kørt 10.000 km, ligger stadig i min bil. Kan komme og prøvekøres, bliver taget ud om 2 uger.
44mm weber
Udstødning CSP Super Competition Exhaust
Stage II kobling
Oliefilter og oliekøler/full flow
New Alum case 1914 cc
Chromoly head studs
CB69mm counterweight/8 dowel /forged crank
CB unitech rods
Engle 110 cam/CB straight cut gears
Scat lifters
26mm heavy duty oil pump
3 1/2 oil sump
94mm cima piston kit
Steve Tims 42x37,5 ported/polished
Scat solid shaft rockers w/Scat swivel foot adjusters
Scat moly gland nut
Lightened flywheel 8 dowel
Drilled for full flow w/steel pump cover w/fittings
Stock valve cover/bales Drilled for breather box
Pris : 24.000 kr.
Morten Gram
40993044
40143121
