  Paint a bobbel
(permalink) Alfredo1303 Member
Hello to everybody I m planning to paint my old 1303 from the 73;
can anyone help me to know where to do it?
Best regards
alfredofranco79@yahoo.it
Where to do it, well on the inside and the outside ! :-) 10 cans
Just kidding.
It would probably help if you told people where your located, so they have a better idea.
Thank you Yankiebar,I would like to do it inside and outside if not so expensive...
I m located in Frederiksberg
(permalink) Teis Member
First of all, a 1303 is not old :P
And second, how much money do you have for paint, because it's not cheaps.
'55 Type 1 med 2-folds
'72 Honda CB350
Is not old...is a veteran.I would like to have an idea about the money that I m going to spend for it.
I would say 15.000 and up.
'72 Honda CB350
Thank you for the answer.I will say that 15000 is not so bad
(permalink) SoLow Member
If its okay in the surface, you could sand it down yourself and then take it to Holbæk autolakering, then they will respray it for you for about 3500 kr.
http://www.autolakering.dk/home.htm
(permalink) Tino Member
Ca 17000 kr på Amager og de har malet en del vw så du siger bare til !
Hilsen
Tino
(permalink) Mr_Bubles Member
Alfredo: try to contact "autolak" inhere, he paints cars and operate in Birkerød, i got his number
Thank you to everybody for the help
Mr_Bubles can I have pls the number?
Solow,that sounds really cheap.
Tino,in Amager where?
(permalink) l.sanderson Member
undskyld det er på dansk men min bror er maler og har osse styr på en Airbrush
vis der sakl lidt lir på.
bobbel 1953. Miss Mango Semaphore split bus 1960
28-43333o
