  Værktøj sælges: Kompressor, svejser, donkraft, motorstand,
(permalink) Kilgod Member
Jeg har solgt huset og skal flytte derfor billigt værktøj Sælges, skal hentes på adressen.
Proff Migger 210 aldrig brugt pris fra ny 17000- pris nu 8000
Det er den store af dem på billedet
The Migger product range consist of basic MIG/MAG machines, designed to meet the demands of welding professionals for lighter repair, maintenance and sheet metal production and they have excellent welding properties.
Migger product range consists of switched controlled rectifier MIG/MAG machines which can be used for steel, stainless steel and aluminium welding.
On the wire feed control panel the optimal range of wire feed speed is shown in different voltage steps. Recommendations are based on using steel wire and mixed gases Ar + CO2.
The machines have a sturdy metal bodies constructed with one-piece cell design giving maximum strength. In addition, a number of versatile functions are available. These include a timer unit for cycle arc/spot welding as well as a 2/4 sequence function. The 2/4 sequence procedure makes it easier to handle the welding gun and increases productivity and welding quality.
All Miggers come with the reliable KMG MIG gun, earth cable, gas hose and fitting plus primary cable and plug and they are ready to weld straight out of the box. All you need to add is correct wire, gas and gas regulator to suit your welding needs.
Kompressor 50 Liter 2800kr
Motorstand med vw holder 500kr
el palle løfter kontakt defekt ellers ok.800kr
Rødt rullebord aldrig brugt 150kr
AC lavfrihøjte til sænket biler med tilhørende bum så der er 2 løftepunkter højtløfter donkraft pris fra ny 6500kr nu 3300kr +skifte til vinterdæk på min bil ;-)
Plasma skære har aldrig brugt den 500kr
Luft tank 150kr
Billeder kommer
Hillerød
Kilgod sikring igennem 8 år
40550750
(permalink) Alex Member
Jeg vil gerne købe plasma skære.
Alex
Type 2 63 panel Type 2 '75 aut Type 2 '78 3xjagtpølse
Kolding/vejle
Tlf 2390 4848
Jeg snupper plasmaskæreren. Hvad er løftehøjde på donkraften?
Lars
24430551 lars(a)ekstromit.dk
Alex du står øverst på plasma skæren (kom først)
Løftehøjden er 80 cm mener jeg
Hillerød
40550750
Super...! Har du et nr jeg kan fange dig på.
Kolding/vejle
Tlf 2390 4848
Andre interreseret kom eventuelt med bud ;-))
Hillerød
40550750
(permalink) kew Member
Lufttank (billede3) tager jeg
Alex. plasma afleveret i Frederiksværk i morges kl 06:00 ;-)
Hillerød
40550750
Super ! Mange tak. Har lige snakket med bjørn og den bliver leveret idag. Tak for handelen.
Kolding/vejle
Tlf 2390 4848
(permalink) Schumann Member
Hvor meget er solgt??
plasma er solgt
Hillerød
40550750
Send en mail det er sjællende jeg er herinde
S@kilgod.dk
Hillerød
40550750
(permalink) Lange Member
Har du stadigt den AC-donkraft?
Leder efter den model
41791477
