  sælges seriøst porsche turbo bremsesystem bolt.on
Kan laves om til bus spindler..
Complete Porsche 944 Turbo brake upgrade for ball joint front ends. The front hubs were machined by VDub Engineering to fit the included CB ball joint drop spindles, and to accept Beetle wheel bearings (new bearings installed). The rear assemblies include oem porsche hubs,backing plates w/ emergency brake shoes, and adapters to use the beetle e-brake cables. These have been installed on myproject car the last year, that was never completed. The calipers work great, and have no issues,or damage. Rear assemblies fit on stock Beetle axles. Here is a complete list of the included parts.
Front:
1. (2) 944 Turbo front hubs, machined to accept oem bearings and fit spindle.
2. (2) New CB Performance dropped Ball Joint spindles w/ 944T caliper brackets
3. (2) 944 Turbo (4-piston) Brembo front calipers + mounting bolts
4. (2) New Zimmerman vented/cross drilled rotors
5. (2) Sets of front brake pads
6. (2) Spindle nuts/bearing caps
Rear:
1. (2) 944 backing plates w/ emergency brake shoes + cable adapters
2. (2) 944 Hubs (attached to rotors in pics)
3. (2) New Zimmerman vented/cross drilled rotors
4. (2) 944 Turbo (4-piston) Brembo rear calipers + mounting bolts/spacers
5. (2) Sets of rear brake pads
More info:
http://vdubengineering.com/new/944t-brakes-on-cb-dropped-disk-bj-spindle/
Pris 15000kr for alt
Boing
Kan også gøre klar til splitbus spindler hvis det ønskes
(permalink) Hansson Member
Er det til irs bag eller svingarm?
VW 113 fra 67, splitbus 67 1600, MKP MIDI 64, MKP GRAND 66
MIB Aalborg
Kan benyttes på.begge systemer
14000kr
Boing
