  helt ny 2332 ccm samle selv S
(permalink) Thomas 356 Member
HELT NY 2332 ALT I NYE DELE
(mangler svinghjul remhjul vippetøj så der en komlpet longblok)
Scat VolksRacer Race-Ready Compete Engine Kit. These kits are engineered for increased horsepower and pre-clearanced for longer stoke crankshafts. Ready to assembly right out of the box.
Top quality parts at a low price.
Eliminate all the guesswork with one of these sensible high-performance engine kits
Rebuild your engine with confidence - all kits include 100% brand new parts.
Easy to assemble engine kits for the performance minded driver or weekend racer.
EACH KIT INCLUDES:
NEW - 94mm forged piston & cylinder kit
NEW - Scat 4340 chromoly gland nut and heavy-duty washer
NEW - Scat 84mm Nitrided VolksRacer 4340 chromoly forged billet counterweighted crankshaft
NEW - Scat 4340 forged H-beam rods - set of 4
NEW - Genuine AS41 VW engine case - machined & clearenced for stoker crank & O/S pistons
NEW - 2 x Mini-D Port racing cylinder heads
NEW - Scat C-45 (W125) performance grind camshaft with gear
NEW - Scat lightweight performance lifters - set of 8
NEW - 3/8 inch heavy-duty cut-to-length chromoly pushrods - set of 8
NEW - Scat 4140 chromoly 8mm dual-port cylinder head stud kit
NEW - Scat adjustable O-ring aluminum pushrod tubes
NEW - Engine case hardware set & 40-piece lock nut kit
NEW - Crankshaft gear assembly kit
NEW - Hi-performance engine gasket set
NEW - heavy-duty oil pump
NEW - heavy-duty main, rod and cam bearing sets - all standard size
pris 26,500kr
hilsen thomas 356 :twisted:
pris ? :P
(permalink) L1 Member
Hmm, bare et gæt så er prisen omkring 26.500 kr......... :oops:
det lyder billigt eller hvad ?
det hele er jo nyt
hvad syntes i andre hard core vw motor bygger
hilsen en ny begynder
Kan den passe i en T1 fra 1968 og kan min gearkasse holde ?
Hvis jeg kan få den i uden de store problemer, er jeg int. i din motor.
Hvis den er som du skriver, er det den billigste ud af de 3 jeg har set på.
Mvh. sørenklm
8) det er billigt men hvis man kigger rundt her på siden er det mulig at købe noget der er til samme penge... husk er der skal told&moms og det svare ca. 31% oveni og så skal man huske fragt og det er dyrt for sådanne nogen tunge motor ting.. mit bud vil nok ligge på ca. 2-3000kr i fragt...og det skal man også betale 31% oveni...
mvh thomas
(permalink) donbug Member
Nu spørger jeg jo nok dumt men skal der betales told og moms af varer fra
(permalink) Anders-DK Member
[quote:3ad17f82e1="ny motor bygger"]det lyder billigt eller hvad ?
det hele er jo nyt
hilsen en ny begynder[/quote:3ad17f82e1]
[quote:3ad17f82e1="Anonymous"]Kan den passe i en T1 fra 1968 og kan min gearkasse holde ?
Mvh. sørenklm[/quote:3ad17f82e1]
Hva med at logge ind, I 2 bøhlas'er ;o) og bruger jeres rigtige profilnavn at poste fra
Og få varene hjem først -ggg-
8) det kan da godt være det er mig men kan ikke helt læse ud fra teksten om det er noget thomas har eller det bare er et tilbud fra scat
hvis det er noget thomas har så er prisen fin...og ja så skal man jo ikke betale 31% + fragt 8O
jeg prøver og sælge noget som kommer til og ligge i kasser i min garage
og prisen er når varen er i danmark
hilsen thomas
(permalink) svendsvin Member
hej thomas hvornår lander tingene sådan ca.???
og var prisen det du mente...
hilsen svendsvin
og kan jeg sætte motoren over i en type 3...
uden problemer
[quote:cd3304b489="svendsvin"]hej thomas hvornår lander tingene sådan ca.???
hilsen svendsvin
uden problemer[/quote:cd3304b489]
du skal selv samle motorn så den vil komme til og passe i en type 3 hvis du bygger den til det eller bus hvis den skal i en bus
forstår du hvad jeg mener
ja prisen bliver 26500kr så skal du hente den i aalborg
jeg har ikke en hjemme nu men hvis du vil have en
kan jeg skaffe den til dig hvis du ligger et lille depositum
hilsen thomas 356
hej thomas hvad kan man tænke sig sådan en motor får af hk.
hvis den er skruet rigtig sammen .....
hilsen svendsvin
den skulle gerne komme over 150hk og et meget stor moment
min egen 2332 giver 172hk og 270nm ved 5500omd
hilsen thomas
hvor lang tid er du om at få motoren hjem hvis du får nogen penge ??
har sent dig en pm svends...
kan jeg ikke få dit telefon nummer så ringer jeg imorgen......
hilsen svendsvin
(permalink) bugs Member
Hej Thomas, er det egentligt ikke bøvlet og skrive alt det lort du skriver med de fælge der?
Mvh. Rasmus
[quote:e9880fb639="bugs"]Hej Thomas, er det egentligt ikke bøvlet og skrive alt det lort du skriver med de fælge der?
Mvh. Rasmus[/quote:e9880fb639]
hvad snakker du rasmus
motor vil være i dk om 6 til 8 uger
er der nogle som skal have en
så har man noget og lave her til vinter
(permalink) mi_j Member
Er det kun en motor du kan skaffe, eller kan den også købes om et par mdr. når der er sparet lidt sammen?
du siger bare til så ser vi på ddet når du har sparet lidt sammen
Det lyder godt, hvor meget skal jeg mere købe hvis den skal ligges i en bobbel fra 56? (er ny indenfor alt det her;-))
(permalink) partyman Member
wow.... smukke tal (læs hestekræfterne og momentet) du fyrer af der! - hvis du kommer til devils island må du RIGTIG gerne gi en opvisning på langelinje. Så gir jeg isen :D
/Party
