  RIP
RIP
"Don't drink and smoke" or how is it that one goes? don't remember... ;-)
You can buy inverters almost anywhere nowadays. Harald junkyard or thansen is probably cheapest
(permalink) SJN Member
YankieBar skrev:
I bought a draugtmaster for my VW, and now trying to figure out how to wire it in.
I assume the best is a converter from 12 v to 230v. Would it be best to wire it directly, or use like a cigarette lighter connector ?
Any place that sells the converters cheap ?
Du skal ikke købe den første du ser. Der STOR forskel på dem. Som hovedregel skal du gå efter dem der giver en ren sinus ud. De er som regel de bedste, men ikke de billigste. LAD V
Med Venlig Hilsen
Søren Nielsen, Kolding
KGB Kolding Gear Boxers
(permalink) cardude Member
(permalink) Mark S Member
Harald skrald har 12v -> 220 v
(permalink) Chritte Member
Wiring it directly would be the best.
you can get this at Thansen ( yes i know)
http://www.thansen.dk/product.asp?c=779724230&n=1199147588&pn=1504956655
the draugtmaster is 80watts right? you can also get them smaller - down to 150w, but thats only for the cigarette lighter.
http://www.thansen.dk/product.asp?c=779724230&n=1199147588&pn=1215731764
but with the 500w, your on the safe side, an it´s for wiring directly.
Anyway - Coool idea..
[quote=Mark S]Harald skrald har 12v -> 220 v
jeg plejer at kalde dem harald flyveborg
de er begge til at tilslutte direkte hvis du bare klipper stikket af og sætter nogle rigtige stik på der kan skrues fast til batteri polerne.
og de der klemmer ville jeg aldrig bruge til noget permanent installation!.
Perhaps you can get a converter directly from th 6 or 12 volts to whatever the draugtmaster use. At cartft.com (computer in your car firm) you can get powersupplies to a computer. If you're lucky it's the same voltage.
24430551 lars(a)ekstromit.dk
(permalink) thogaa Member
Harald Nyborg sells the same inverter as T Hansen but much cheaper. I've had my 800W inverter from Uncle Harald a year now running a notebook, laserprinter and a waterpump ind my car. I've wired it directly on to a second battery in the car connected with charge relays so it won't empty my main battery.
Connecting it to the cig lighter will cause fire or worse!
40818888 gaardsoe.com
Bay window hippie bus owner
I didnt know that... Dear old Uncle harald.. hehe
Nej, det ville jeg heller ikke, men jeg vil hellere smide de ledninger væk og bruge skrueterminalerne på 500w´eren end klippe i ledningerne på den lille og bruge dem..
Oh - forgot to mention that Biltema supplies a very nice battery box to keep the other battery in the trunk...
smag og behag, jeg har personligt ikke problemer med at lode en samling og give den noget krympeflex hvis de er for korte.
(permalink) jakob356 Member
Hvis nogen synes, at sådan et fadølsanlæg er verdens bedste julegave, så læs lige den her først:
http://politiken.dk/indland/article210356.ece
(koster selvfølgelig ikke så meget på hjemmets elregning at montere den i bilen, men der må man nok regne med at skulle have fat i startkablerne en gang i mellem)
JAKOB
(permalink) Chefen Member
Jeg hørte i radioavisen i morges (fredag), at de der draugtmaster som tuborg sælger er de rene strømslugere.
De bruger 5 gange så meget strøm som et almindelig køleskab, så ....d´en OMér.
RIP
Hey Yankiebar
Hvis du kan læse dansk, hvorfor kan du så ikke skrive det. Perker.
Well you know, its actually a long and funny story, so give me your name and phone number, I can call you and explain it to you.
Vi snakkes, og ha det godt, Coty
(permalink) ploug Member
Anonym skrev:
Hey Yankiebar
theres one born every second !
mobil nr: 22-26-03-12
RIP
(permalink) Leth Member
Anonym skrev:
Hey Yankiebar
Du er godt nok barsk derude bag tasteturet. Anonymt! Din mor må være stolt...
Man kan kalde Coty mange ting, men Perker er nu ikke det første der falder mig ind :-)
Mvh Jakob
Vedkommende er kontaktet og melder forhåbentligt tilbage her.
coty er ligesom ikke fra den del af verden som almindeligvis referes til i forbindelse med perkere. og desuden så er perker et urdtryk for hvordan folk opfører sig ikke hvilket sprog folk snakker.
desuden så kan det være at vi misforstår anonym, tror i ikke nærmere det er skrevet som det er med et punktum før ordet perker. for at angive at det er en underskrift, at anonym simpelthen hedder/kalder sig selv perker ligesom at jeg slutter af med mit navn for at indikere at det er noget jeg mener det her og skriver under på det. Erik.
ip'en tilhører
Dairy Fruit A/S
Hestehaven 3
DK-5260 Odense S
RIP
