  Double Battery set up
Sorry everybody, I actually have a question about VW's , I hope that is ok on VWNettet ! :-))
I suck at wiring in a car, can somebody draw a basic drawing of how to set up 2 batteries . This winter when I actually get working on BadBug, I will be hiding all the stereo hardware to make the car more Retro, but would like to be able to play the DVD when the car is off, without worrying about draining the battery.
So are the batteries wired parallel to each other with a shut off switch on the main wire to the second battery ?
PS: If I have bought something from someone and have not picked it up yet, let me know with a PM so I can correct it ! :-)))))))
you can buy a battery switch in a caravan center , who automaticly swap over when the battery is to low on power ..
an when you are driving and charging the batterys - it switch automaticly back agian..
and a wirring drawing goes with it to...
Bornholmer, this is a danish forum, you have to write in danish ! hehehehe
Tusind Tak , Jeg skal samler helt vildt masse penge of besøge en caravan center i morgen. :-)
Du kan også bare bruge et relæ der bliver styret af lade lampen mellem batterierene, meget billigere og virker perfekt!
Det virker så at batterierne er adskilt når motoren ikke kører, men når motoren startes og ladelampen slukker, så er de koblet sammen!
Hvis det ikke er nu og her du skal have lavet det, så skal jeg nok komme forbi og fikse det!
Jesper
Tak Danborn, Det haster ikke, men vi kan plan en hygge dag i garagen.
