  Hvordan ....ser man type på en splitbus camper
(permalink) Clausenvw Member
Hvordan ser man hvilken type camper det er man har...
Mener ikke mit typeskilt siger noget om dette..
Ej heller attest fra Wolfburg
Ville det have stået her, hvis det er en org. ombygning..
Eller står det på selve indretningen... ?
69´ Porsche 912
73´ Porsche 914
SO1 Westfalia mobile shop
SO2 Highroof mobile shop
SO3 Police: Mobile office/road traffic accident emergency vehicle
SO4 Police: road traffic accident emergency vehicle (from 1965)
SO5 Refrigerated vehicle with 140mm insulating board
SO6 II Refrigerated vehicle with 80mm insulating board
SO6 III Refrigerated vehicle for meat products
SO7 Frozen food transport with chiller
SO8 Pick-Up with hydraulic lifting bucket
SO9 Pick-Up with hydraulic lifting bucket
SO10 Pick-Up with hydraulic lifting bucket (smaller than SO9)
SO11 Pick-Up with turntable ladder
SO12 Pick-Up with steel shutter access to enclosed storage box on bed
SO13 Pick-Up with enclosed storage box on bed
SO14 Pick-Up, Kombi, or Panelvan with carrier for long pipes or poles
SO15 Pick-Up with hydraulic tipper bed
SO16 Double-Cab Conversion (Binz 1953-59)
SO19 Exhibition and display Bus
SO21 Pick-Up with wide-load bed (from 1965)
SO21 Panelvan fitted with Wido multi-layout shelving system
SO22 Westfalia camper kit
SO23 Westfalia camper with small roof hatch
SO24 Pick-Up (Single or Double Cab) with trailer for longer pipes or poles
SO25 Pick-Up low loader
SO29 Ambulance trailer with emergency disaster equipment (until 1964)
SO29 Catastrophe and disaster emergency vehicle
SO30 Ambulance with rolling stretcher undercarriage assembly
SO31 Pick-Up with heating oil tank and dispenser pump
SO32 Pick-Up with roller blind access to enclosed storage box on bed
SO33 Westfalia camper with small roof hatch
SO34 Westfalia camper with small roof hatch and white laminate cabinets
SO35 Westfalia camper with small roof hatch and dark wood cabinets
SO36 Side elevating roof (Dormobile top)
SO42 Westfalia camper
SO44 Westfalia camper with small pop-top in roof
SO45 Westfalia camper kit "Camping Mosaic" (similar to SO42)
http://www.westfaliaregistry.com/
men du skal jo ha sæder i har jeg hørt - så er det jo ikke en camper mere.
Så ved du mere en jeg gør.....Jeg indretter da til camper, men med bluebird R/R bed
samt selvbyggede skabe...er godt klar over at den så ikke er en westy vedr. indretning...men det var selve typen jeg efterlyser, men prøver lige at kigge på dit link...
P.S du havde set PM med dine dele...de afsendes fra mig idag ...
69´ Porsche 912
73´ Porsche 914
Det er selve typen på ombygningen jeg efterlyser..
Var der nogen amerikanske ombygninger i 66-67 , så den kan være ombygget i US ?
69´ Porsche 912
73´ Porsche 914
Vil mene at der skal stå A42, B42, C42 eller D42 på dit type skilt.
På billedet ser du typeskiltet fra min SO23.
A23 en af de 8 koder en SO23 kan have alt efter udstyr.
AircooledBoxer.dk
Har nu mailet med en del på Thesamba...det ER en amerikansk opbygning
Den er fra Travel Equipment Corp. produceret i Elkhart Indiana - 1966 samt 67
Også kaldet sportsmobile....
( åbenbart lidt sjældne - ifølge dem på Samba )
69´ Porsche 912
73´ Porsche 914
Hvilke detaljer fortæller at det er en Sportsmobile?
AircooledBoxer.dk
Det mest iøjenfaldne er en plaquete på pop up taget hvor der står Travel Equipment Corp.Elkhart Indiana, men dette skilt har jeg først antaget som noget senere monteret , da jeg jo købte den som en " westy ".......
Men ifølge oplysninger fra de oversøiske "bussemænd" skulle det være ganske vist, at der blev ombygget busser derovere i 66`samt 67`, og at netop udformningen på pop up taget samt den fastmonterede liste til sidetag/telt er et af disse kendetegn...
Ligeledes at der intet står på bilens typeskilte, ej heller fødselsattest....
Er der nogen der ved noget om disse typer campere, her i DK, evt. bøger/blade , andet der viser lidt vedr. dette...
Jeg afventer i øjeblikket oplysninger fra en gut i USA , der mener hans far har noget udstyr til en sådanne liggende..., samt fotos fra en sådan bus...
69´ Porsche 912
73´ Porsche 914
