  Batteri Amp ?
Buying a new battery for one of my VW's and curious about amp size.
If the physical batteri size and has the correct position of poles , then does it matter what size amp it is ?
Things i read is, 35 is ok for standard VW, 50 is better, but if big motor and stereo, then a 65 is best.
Can a over size battery do any harm ? Like the generator ?
Coty
(permalink) jpwest Member
Køb du bare et 200A hvis du kan få plads,det betyder ikke det store,om du så får ladet fuld knald på(200A) er så en anden sag
West
(permalink) Mbechmann Member
Coty, in Finland EVERYBODY drives with 65amp as standard - with no problems what so ever.:) Actually if you dont use that, your car wont start doing wintertime:)
Michael
