  Bug byttes til Bus , har du en ?
59 Show Taxi Ragtop + danske kroner for a split bus or crew cab.
Anybody have anything interesting ? Must be close to turn key.
Only SERIOUS people please that are ready to handle ! Emails only to coty@tdcadsl.dk
more info and pictures posted later.
Couple videos
http://www.youtube.com/watch?v=iOVRRyYJMks
http://www.youtube.com/watch?v=tHNm8Oz1JkI
http://www.youtube.com/watch?v=63InmmdyXSY
Not needed anymore, got my bus, not the crew cab I wanted, but a very cool bus.
Technical Modifications :
Drive train:
• 2.0l-Typ4-engine with Porsche-fan-wheel
• Twin-carburetor Weber 40mm
• Gearbox from VW 1303
• Additional oil cooler at front axis (Mercedes Benz part)
Chassis and suspension:
Front axis:
• Height adjustable front axis
• Adjustable Spax dampers
• Disc brakes with inner vent from Kerscher
• Porsche Fuchs wheels: 5,5x14“, 185/60 R14
Rear axis:
• Diagonal bars (rear axis from automatic beetles)
• Torsionsbar 1 tooth pretension
• Drum brakes
• Porsche Fuchs wheels: 6x15“, 195/60 R15
Body:
• VW-Sportseats
• Momo-driving wheel
• Instruments from Porsche 914
• Cleaned dashboard  switches underneath
• One piece windows, electrical
• Indicators
2.0 motor with the new python exhaust.
Absolute no rust, restored 10 years ago by father and son that work at concept dept at VW.
Afgift paid for all the non standard vw stuff.
VW taxi decals can be removed.
25k in taxi rare items included including a taxi cap , all that stuff can be sold on ebay if not wanted.
There is only 2 cars in the world with the interior cloth and the other vw is in the VW Museum.
VW was cover car for VW Scene in 2000 Sept issue.
Only 4 small things wrong with the car, the rubber on the trinbrat under the driver door should be replaced. 100 kr to repair The small area behind the motor area where the exhaust hole could use a repaint. Probably 300 kr to repair And the new exhaust is very low, so carefull over bumps.
And a sten slag in the front window. That is it, everything works, including the electric windows, hazard lights, side blinkers, stereo, amplifier, etc.
Absolute no rust .
Låner lige indtil videre tråden fra Coty :-) Håber det er ok.
Bilen er til salg af mig nu, eller bytte med split bus.
Pris ring er alt efter om der er cash eller bytte.
Den er stadig på plader og klar til at køre i.
Den er nu monteret med kopi Porsche Gasburner fælge med 145/65 15 dæk foran og 195/65 15 dæk bagpå.
Ser sådan her ud i dag, alt er intakt på nær "taxi" udstyret.
Hilsen Per
http://www.aircooled.dk
Er fra AA
(permalink) vw1303 Member
Står den stadig på mexicobund eller er den skiftet ud med en tidstypisk bund svarende til toppen??
1303 big & ?????????????
vw1303@paradis.dk - 20484650 - Sønderjylland
Tønder veteran klub
Vw1303 spørger du af køber grunde eller er du blot nysgerrig, for jeg ved det heller ikke, men vil da gerne undersøge det for dig hvis du er seriøs. Ved blot at den står som da jeg købte den minus ombytning af fælge.
Hilsen Per og du er velkommen til at ringe eller sms til mig.
Er fra AA
Det var bestemt en seriøs henvendelse. Men det det jo en del at betyde da årgangen på bilen jo er bestemt på bunden.
Tønder veteran klub
lyder godt vw1303 du ringer bare på 40 59 40 59 hvis der er spørgsmål til bilen Hilsen Per
Er fra AA
Ingen?
Er fra AA
Er fra AA
Er fra AA
Boblen skal væk nu...
Byd eller kom med bytte forslag, med uden motor.
Send en email eller SMS
Hilsen Per
Er fra AA
