  How high is the standard bus ? garage clearance question
Not that i have one, but getting ready to finish the new garage area, and working on the entrance door. What is the height of a standard bus without roof rack of course ! :-) Just in case I win the lotto.
1.90 give or take a little (splitbus)
(permalink) Mr_Bubles Member
Hey Coty... i asked the same question a few months back.. some one send me a data sheat, and it was 194cm stock... so to Rasser: its "Take a little" *G*
Så siger vi sgu 2m, så er det da på den sikre side ;-) (så kan den også rulle ud af garagen uden motor i)
Tusind tak, now I need to go out and measure ! ;-)
But then again, Airkelwd has an air ride kit to help !
http://www.airkewld.com/pages/welcome.php
De er mellem 1920mm og 1940mm alt efter model. Dette er målene i 1965.
AircooledBoxer.dk
Min Garageport bliver 2110mm så håber jeg der med tiden bliver til en bus!!
JEP... lige det dokument jeg så
Husk nu bare på at det laveste punkt tit og ofte er motoren der trækker porten op!!
(permalink) Rene72 Member
Og husk en camper med hævetag er højere..
2074 1572
Just measured, its 208, so its cool for the future.
hey coty i have a sick new frontbeam narrowed and with org. needle bearings, and new bustang brakes and 4 piston wilwood calbiber and with drop spindles.. its a turnkey beam.. made by the best in the us Wagenwest... and it comes with new adjuster spring plates for the rear---
total upset 20K
sorry forgot to say its with vw wide 5 but you can take the spacer of and drive with old school wheel FORD MUSTANG
ok Micha , if I am ever lucky or rich enough to buy a split bus, I will keep you in mind ! :-)
okay :))) call me if you need it
