  Sælges: 1745 Turbo
(permalink) Blob Member
Typ1 1745cc Turbo engine for sale.
Injection and ignition is controlled by Megasquirt. Ignition is made as Waste-spark.
The engine has been driving 1000km.
Longblok build by Torben Alstrup.
NEW:
Brand new killer blok
Crankshaft 76mm with Counterweights
Camshaft Web 218 turbo
044 Heads
Unitech rods with bolted ends, machined for lubrication under the pistons
Forged Pistons
Push Rods Chrome-Moly
Fuldflow oilpump
Extra oilsump
Header and exhaust made in stainless steel
New t3 turbo
Watercooled intercooler, including pump and cooler
WB lampda-sensor, and LC-1 controller from Innovate Motorsport
Waste-gate: Tial MV-S, (the new model)(incl. spare springs)
Dump: Tial Dump-valve
DTM coolingsystem, incl. new alternator
Injectors
Coil for wasted-spark
MSD ignition cables
All hoses are new AN-hoses
MegaSquirt, with almost everything on-board
GT1 Hall-sensor
Automter Ultralite pressure gauge incl sensor
Lightened flywheel
Stage 2 pressureplate
Clutch
Alu-fuel rails
Magnaflow muffler
In-line oilfilter for the turbo
I am sure I have forgot a lot of things, so just ask if you have any questions.
The engine is still in the buggy, so it is possible to come and try it.
Except from the intake manifolds, is everything brand new.
(permalink) JonasWittendorff Member
Jeg går næsten ud fra at det kræver en større omgang at smide den bag i en 67'er bobbel?
Knaldebang-grøn 67'er Skydetags-Bug, 1600 dobbelport.
Ja der skal nok laves lidt tilpasning, men hvor meget det nøjagtigt er ved jeg ikke.
Men et par timer hos en rustfri smed så tror jeg man er kommet meget langt. Det kan ikke være så slemt.
Alle flanger osv kan jo genbruges, så det burde være til at overskue.
er der nogen måling på motor her tænker jeg på nm og hk
Nope, jeg har ikke en gearkasse der kan holde til det.
Men ca. 170hk v. 0,7bar og 220-230Nm. Der medfølger fjedre til at lave over 1 bar, så de 200hk skulle nok kunne hentes.
Din gearkasse kan da sagtens klare at blive kørt i et rullefelt, det går den da ikke i stykker af - eller?
Tror du ikke en std. gearkasse/aksler brækker hvis man forsøger at klemme 200hk igennem?
overhovedet ikke. spørg bare frank hvad han brugte til hans 2.6L type4 ..... :-)
Der er jo forskel på at lave en dragstart med slicks, og så liste rundt på landevejen/rullefeltet.
Flot motor iøvrigt!
Ja det har jeg godt hørt om. Hmm jeg synes bare stadig at det er risikabelt, men hvis der kommer en person som er seriøs, vil jeg godt være med til at lade det komme an på en prøve. Så det skal ikke være det som stopper.
Takker
Du behøves slet ikke være så nervøs, det er stærkere grejer end man lige skulle tro!
(permalink) crenne Member
suuuuper flot motor
tlf 41666671
Men ja man kommer langt ved at tænke over hvordan man bruger tingene.
Men nu tilbage til salget. Hvis nogle ønsker bevis for effekt kan den komme på rullefelt, samt afprøves monteret. Men kun for de som er seriøse.
(permalink) Lange Member
Blob har du et telefonnummer man kan fange dig på?
41791477
Kig din email lange:)
Slettet.
Ny Pris
