  S:2275ccm motor
(permalink) RoadHog Member
Tel 29385492
2275ccm motor just run in after a rebuild
Full list off parts and price to come..
Engine part list
As41 Engine case,full flow,clearanced for 82mm crank amd 90.5 piston
8mm chromoly head studs
Scat 1.5 litre deep sump
shadek oil pump with full flow cover
82mm cb 4340 forgrd chromoly crank
forged and lightened flywheel
Scat chromoly gland nut
New Engine Bearings
Scat Billet Crankshaft pulley
Scat H/Beam rods 5.5 length
Web cam 86 or Fk10
Straight cut cam gear
c.b racing push rod tubes
Scat lightweight cam followers
Chromoly scat pushrods
Dual thrust cam Bearings
Mahle 94mm pistons cut down to fit 90.5 on engine block
Cylinder Base spacers
Drd L5 heads
Kennedy performance pressure plat stage 2
1 3/4 merged header
Pris motor 38k
(permalink) jbillj Member
Open to a good offer...Can be had as a turn key motor...009,msd,Weber 44s
(permalink) Roadrunner Member
Price as turn key? and can you help build it in a buggy?
Ha Roadrunner like the name....
We could talk about what you want to do...
Helping out in the Vw family just ask..
Turn key 38k
How Can i reach you? Mail?
How Many hp and torque does the Engine put Down?
Ha Roadrunner this is my Mail,Matvw74@cool.dk,phone- 29385492 I think I would like to keep the msd box at this time.I have no hp reading but must be easy over 130
Hi Roadrunner the engine is in my vw so if you would like to see it run you are very welcome...
Turn key 35k
No one wanna have some real power in there Vw??
Short block 25k
009,Weber 44s Youtube. http://youtu.be/YlnZl4pOmRs
Matt 29385492...
Short block 25k Tel 29385492
Does This meen that you've Taken the Engine apart?
Hi Roadrunner on just as removed for my car...
I send you an email but you haven't answered ?
(permalink) dannykok Member
hey.
do you still have the engine ??
Yes I do....
Oki. Where du you live?!
4370 Store Merløse
23000k as a short block...
(permalink) Mollerbaby Member
Is the engine still complete as an turnkey?
Hi Mollerbaby I have all most all that is needed just need a 009 and spark lead set if that's good enough?? Have an Msd box to..and the 44 webers Mvh Matt
