  Empi five-spoke original??
(permalink) Morten03 Member
Halløj
Er empi five-spoke original udstyr til vw i 70'erne??
De er på bussen og det er til forsikring, så den er holdbar, ellers skal de skiftes ud :-)
Så JA eller NEJ?
Mvh Morten
1977 Bay Bus
ja - de findes orginale - svend har dem på sin bus....
de kan ikke findes i et org udstyrskatalog dog - som diffinationen på org er
lidt svævende......
de findes ikke i et vw katalog som feks BRM eller lemmertz fælge kan findes.
et empikatalog fra 1966
Det er nok ligemeget om det er en kopi nu, men det skal nok kunne bevises, at det var udstyr dengang...
1977 Bay Bus
(permalink) ses_auto Member
EMPI 5-spoke
Datasheet
Description
EMPI offered 5-spokes for Volkswagen, Porsche 356 with added clearance (the bolt that keeps the rim halves together touches the Porsche drum) for larger drum and Porsche 911 (see the photo below) version with later model Porsche bolt pattern. Original wheels are called split rims since they are in two parts and have to be splitted in order to change the tyre. This also means that the tires are tube-type.
EMPI style 5-spokes (copies) are probably the most common custom wheel today. Copies are manufactured by Rocket, Midland Wheel Supplies and American Eagle.
Originals can be quite easily spotted from fakes by the shape of the spokes, shape of the outer rim and the center caps are attached with 5 screws. Also the cooling fins inside the wheels are somewhat visible to the outside.
Original 5-spokes are known to crack around spokes and lug holes if they have been abused or over tightened. On the other hand these cracks can be repaired professionally and they are still quite strongly constucted but they were manufactured over 30 years ago.
Center caps are quite close to American Racing center caps, so these can be substituted if originals are missing. Reproduction center cap decals are available from Matt Joy.
Manufacturer EMPI, USA
Production lifespan 1967 - 7?
Size Originals are 5 3/8x15", copies typically 5.5x15"
Weight n/a
ET n/a
Additional photos
1) EMPI 5-spoke for Porsche 911 bolt pattern.
2) Original EMPI center cap on the right and American Racing center cap with repro decal on the left. When attached to the wheel, there is not much difference.
Copies manufactured by Rocket
Copies manufactured by Rocket Industries can be identified by manufacturers castings.
Hej dette skulle kunne dokumenterer at dine hjul er originale five spoke og blev lavet til VW og Porsche
Hjemmesiden hedder terovirta.com/
Hilsen
Ses-auto
Alt hjælp er godt, men rigtig hjælp er bedre, så lær FØRSTEHJÆLP før det er for sent.
Fedt!!
Mange tak
1977 Bay Bus
(permalink) Gustav_t Member
Dokumentation for cosmics... er det lige så nemt?
1964 Type2 1969 callook
Her er lidt tidskorrekt info, dog ikke meget
(permalink) av Member
hej. hvad så med centerline? mvh. av.
69 1200 sparkæfer.74 baja. villadsen@aol.dk
deano dyno soar kørte med deres centerlines start 70 på deres racer - men mener du orginale centerlines ved jeg det ikke.
men de var da meget populære i midten af firserne.
