  1967 type 1 cal look
(permalink) bang Member
Vel nok en af Danmarks fineste cal look biler. US model 67 med alt det rigtige grej. Bilen har kørt ræs i USA og er meget flot. Den er på danske plader nu og alt er enten from, show lak eller poleret. Den er super flot special syet kabine. Der ligger en gearkasse i bilen der kan tåle stryg.
Sælges kun for jeg har set realiteten i øjnene at jeg nok ikke får den brugt nok med 3 små børn.
95000 med plader lige til at køre hjem i.
22971295
annonce fra tidlige ejer
The car is a 1967 one year only type 1, which is imported from Californinen at the beginning of 2010. The car stands as a shiny candy. There are no welded in the car, and no rust at all. And it has not rolled a meter, since I got it home.The car was then back built by Rich Dickson, who competed in the series Der Renn Kaefer Cup (DRKC). A series where the cars were judged on both how they looked and how fast they were. a class how many DKP cars increased in. Rich Dickson was the first who came under 11 seconds on the ¼ mile, with a time of 10.90. The car was also in the HOT VWS 2005. http://www.cbperformance.com/Articles.asp?ID=265 the car is built from the ground up, and there are not spared.
Of parts, include:
T-bars, with Greg Anderson, signed/engraving
CB lowered and narrowed beam, with CB lowered spindles, as well as CB 5-205 disc brakes.
Fitted New Hurst Line lock. Button sits on the gear stick, and works :-)
Brand new rear brakes, rollers, trays, bearings, brake lines, and more. Everything new.
Sway a way sprinplates, JLC spring retainers 28 mm sway a way tosion bars.
10/90 dampers front, RLR in the back with limitstraps.
Gene berg welded transmission brackets, and solid rear bracket
KRC Ultrastreet transmission, with 3,88 ring pinion, Erco gear, Erco side cover, guessed case, superdiff. DKP gearing, 3.78 1st, 2.35 2nd, 1.65 3rd, with 1.26 in 4.
The gearbox is also new and have not driven one meter. Can be sold separately
New akseltubes and saw HD aksles , with nuts in titanium from csp.
Full detailed org gasoline tank, with AN 6 hose to the vent.
Holly blue pump, with AN8 hose all the way, to the regulator. Aeromotive fuel filter and regulator.
Hi torque starter
Wheels:
Erco rims all the way around, with 3.5 'front and 6”in the back. Just like new. Crom nuts, with matching alloy shims in blue. The tires are Phoenix in the front, and MH tires in the back. 215/15 new also.
It stands perfekt!
Interior:
There are original pop outs
Ron lummens DKP cage, which is painted in the car's color
Flat 4 gt steering wheel
Gene berg old type shifter
Simpson Platinum H harnesses
All in Auto meter instruments, from pro comp series. With oil-pressure gauge in the glove compartment. Big wigrace cars alu interioer in the doors and the area at the rear.
Rear seat included. TMI carpets, etc. Original seats that are redone in colorado usa Sewfine.
New Red optima battery
Generally:
The car is painted in a Porsche silver, with a blue tones in. Then with Clearcoat. But the pictures speak for themselves.
There are an incredible number of hours done in the car and is worth a look. Only serious inquiries! There is spent alot of money into it.
tlf 22971295
supersjov sommerbil. går rigtig sød og vender hoveder.
tlf 22971295
stadig her klar til sommeren
tlf 22971295
99999,- hvis den skal blive i danmark. så kan du køre til bugs under bøgen i den
tlf 22971295
Nogle bud. Har fundet anden bil jeg vil have
tlf 22971295
95000,-
tlf 22971295
Highroof earlybay?? ?
Nej vil have en ny rallybil ;)
tlf 22971295
mail
peterbang.hm@gmail.com
for flere billeder
tlf 22971295
Stadig her.
tlf 22971295
90000 som den står eller 80000 uden motor
tlf 22971295
tlf 22971295
(permalink) martin Member
Utroligt at den ikke er solgt i nu.. Den ser super fed ud.
Skulle du måske lave en masse flotte billeder, som folk kan forelske sig i.
karmann martin
nu med lidt billeder
tlf 22971295
ingen der kunne være lun på en rigtig fin vogn
tlf 22971295
(permalink) Liliendahl Member
Super fin vogn, har dog lige en BMW328 cab der skal afsted først :0(
Morten - 26123260
mt.liliendahl@gmail.com
Hva pris står den til? Info på peterbang.hm@gmail.com
Tager gerne anden special bil i bytte.
tlf 22971295
