  svar Type 3 eftertænding, dårlig varmstart mv.
Vi kommer jo langt omkring i dette forum og meningerne er mange og lærerige,
Men spørgsmålet som udgangspunkt var jo
bpkk@post.tele.dk 20 12 58 04
(permalink) jpwest Member
Imponerende viden
West
Ja, fine guldkorn
(permalink) Jvang Member
sådan, det kan man sgu da bruge til noget, fik svar på mange af mine spørgsmål, har lige set det mærkat på min motor, hvor der stod o,10mm... det giver pludeslig mening1
tak
Der er da vist en af dem som skal i FAQ, ik' ??
-Tonny
[quote=Tonny Larsen]Der er da vist en af dem som skal i FAQ, ik' ??
-Tonny
:wink: jo..
~Mette
Dear Sir, madam. Our logistics company, STS Logistics looking
for people for work from home in USA, Germany, UK, Spain & Australia
We are searching for active workers, male/female from 18 years old.
We are ready to offer you an interesting job and partnership.
Requiments:
-basic english
-internet
-computer
-2-3 hour free time
Monthly salary will be about 3000-4000 USD! And this is real with us.
Regards,
John Campbell
For more info send e-mail: job@onlinests.org
You will have all information!
Requiments:
-basic english
-internet
-computer
-2-3 hour free time
Regards,
John Campbell
STS Logistics is searching for active people for good and prospective work.
JOB OFFER:
STS Logistics is searching for managers, we will provide good salary and
profits ( 500 EUR - 2000 EUR per week), first 15 candidates will get
invitation to start working in our company.( 10 countries are working with
our company today).
Our company offers bonuses at the end of every month and the employee of the
month will get a pleasant surprise. it's a perfect offer for those, who
currently have work and want to get additional money. It won't take much
time, just 1-2 hours a day. Think about it, it's not hard and well-paid.
Interesting work with people and Internet. If you are 18-60 years, write to
this email:job@onlinests.org
Hello,
My name is John Campbell, I represent STS Logistics company
located in the USA (offices in Germany, Russia and Japan).
Our company is seeking for a representatives part-time jobs in the USA, Germany, Spain, UK, Australia.
This is not spam and we will not ask any money from you.
Your minimal income will be $2000USD a month in average. You
will be paid weekly.
No relocation required, job duties include mail and payments
processing, standart office duties and everyday reporting.
All candidates have to be authorized to work with minimal
computer knowledge.
If you're interested in this Job please
contact us through the contacts below:
Best Regards,
John Campbell
JOB OFFER:
our company today).
Hello,
computer knowledge.
Best Regards,
John Campbell
Your blog is interesting!
Keep up the good work!
Hvorfor ligger denne tråd stadig under FAQ ?
Det hele er jo gået tabt efter det nye vwnet er kommet ...
/John
Hej John.
Her hele teksten:Vi kommer jo langt omkring i dette forum og meningerne er mange og lærerige,
Men spørgsmålet som udgangspunkt var jo” vanskelig varm-start og eftertænding”.
Eftertænding er jo et fænomen som primært forekommer på luftkølede biler
p.g.a vanskelige køleforhold af topstykket, hvorved enkelte punkter i forbrændings-
kammeret under- og efter (hård!) kørsel er glødende (det kan også være koksrester der
gløder). Glødetænding er således ikke en fejl, men en konstruktionsbestemt ulempe!
Glødetænding kan bekæmpes på to måder!
Lad motoren køre i tomgang et kort stykke tid inden den stoppes, derved nedsættes
temperaturen inde i forbrændingskammeret og de glødende områder ”går ud”.
(efter)monter tomgangsmagnetventiler som afbryder bensintilførslen til tomgangs-
systemet når tændingen afbrydes. (så er der ikke nogen bensin der kan glødetænde)!
VWW var selv opmærksom på dette allerede i 1961 da den første type 3 kom på
markedet, således er alle enkeltkarburatormodeller af type 3 forsynet med tomgangs-
magnetventil.
På type 3 1500 S blev disse ventiler monteret efter april 1964.
Når problemet var mere udtalt på type 3 var det fordi disse motorer ydede mere og
derfor også arbejdede med en højere temperatur.
Motorrummets udformning bidrog ligeledes til dette.
Dette har også indflydelse på det første spørgsmål, vanskelig start ved varm motor.
Som alle der kører type 3(forhåbentligt) ved er bensinpumpen forsynet med en plasik-
kappe som skal forhindre at bensinen i pumpen fordamper så der dannes dampblærer
(luftlommer) i pumpen. Dette sker på ”sugesiden” af pumpen og forhindrer at denne
kan suge bensin fra tanken. Denne plastkappe er altså vigtig!
Dampblærer kan også opstå i fødeslangen til pumpen hvis denne ligger for tæt til motor-
blokken, derfor var denne slange anbragt i en holder ovenpå cylinderkappen for cyl. 3 og 4,
eller i en holder på oliekølerens befæstigelsesbolt.
Det er også vigtigt at bensinslangen fra bagerste rammegaffel til motoren ikke ligger
langs/opad varmeslangen fra varmeveksleren i v. side.
Alle disse forhold bevirker at motoren kan have vanskeligt ved at suge bensin efter
længere tids kørsel, og dermed vanskelig start!
Startproceduren ved varm motor er, som nævnt i tidligere indlæg, anført i instruktionsbogen.
Da kompressionen er højere ved varm motor kræver dette en højere overslagsspænding
I tændrøret! Derfor er det vigtigt på 6 v. anlæg at tændspolen modtager min. 5 v under start-
forsøget. Dette kan måles med et voltmeter mellem tændspolens kl. 15 og stel. Er dette ikke
tilfældet skal der monteres et hjælperelæ som giver tændspolen spænding direkte fra batteriet
mens starteren kører.
Tændingstidspunktet skal stilles statisk på 10 grader før top. (midterste mærke hvis der er tre
markeringer, og det første mærke der kommer op hvis der er to markeringer.
En 1500S skal køre på 95 oktan.
Topstykkerne blev først ændret til firekantet vippearmssokkel i marts 1965.
Alle VW-motorer (type 1, 2,3 og industri-) før denne dato var forsynet med rund sokkel.
På topstykker med rund sokkel var vippearmsmonteringsboltene ikke fastgjort i
vippearmshuset, men i selve topstykkets anlægsflade mod cylindrene! Dette betyder at
ventilafstanden formindskes ved stigende motortemperatur, hvorfor ventilafstanden
skal indstilles til 0.20 mm indsug og 0.30 mm udstød. Ved kold motor.
Ref: VWW teknisk meddelelse nr. M-6, marts 1965.
Udover den runde sokkel, kan man se disse lange bolte ved at kigge på bagsiden
af vippearmshuset. Disse bolte havde tendens til at gå løse, hvorfor man ved service-
eftersyn skulle afmontere vippearmene og efterspænde disse bolte!
Der blev senere udleveret ombytningstopstykker med rund sokkel og kort monteringsbolt
fastgjort i vippearmshuset, og med ventilafstand 0.10 mm. Her medfulgte et lille skilt
med påskrift 0.10 mm til at klemme om vippetøjsakslen.
Disse korte eftermonteringsbolte kunne købes under resdl.nr: 311 101 061 BY
Ref: rep.håndbog type 3 udgave 1965.
Torkild
Fedt Torkild - sådan :-)
/John
