19:06 jbl: Type 3
17:05 tobje1000: Tobje1000
  VW Pickup Bus with Gul eller Historic Nummer plade question.
What is the difference in regards to cost per year. Is there a difference in regards to vægt afgift ?
(permalink) jakob356 Member
Under 2 tons totalvægt er den virkelig billig på kvart veteran afgift. Og registreringsafgiften ved import er også lav eller nul.
Men gule plader laves vist ikke som historiske.
Se vægtafgifter her: http://www.skm.dk/tal_statistik/satser_og_beloeb/242.html#tabel5
JAKOB
Hvis det er en første gangs registrering i DK, får man den vel bare regget som personbil, så er der vel ikke noget i vejen med at den kan få en historisk plade.
Men lige pt kan du kun få historisk plade til og med marts 1958, så det må være en ældre dame du har på tapetet Coty (?)
22143315 eb@soundforce.dk
(permalink) Kaj Member
Hej!
As far as I can understand your question you are asking about a pickup, right?
I got mine imported and registered in june/july, registreringsafgift was 0,- and vægtafgift is 785.- pr. year on yellow plates..
I don't know what the price would be on white plates, but I think it would cost more, people with busses pays somewhere between 3-4-5-6-7000 as far as I've been told..
I was told that you could nedveje "downsize??" the registered max weight so that you would go under 2000kg, then vægtafgift would be 453,- (mine is registered for 2170kg. in total, won't be carrying that much cargo..)
It's 25% of the figures in "Varebiler og mindre lastbiler
(indreg. før 25. april 2007)"
http://www.fdm.dk/public/biler/okonomi/afgift/vagtafgift.htm
By the way it's a '68 bay, don't know if the price is different for a split but I don't think so..
ex '68 T2 pickup
'53 oval
'87 T3 2,1WBX
