 [closed] skal du/har du handlet med pick-up jens???
(permalink) VW TAGE Member
jeg giver hassan ret. og syntes den her tråd er blevet rigtig latterlig, fordi den har vendt sig til at være meget personlig. og enig i at folk ikke burde tage røven på hinanden, men alle folk sælger vel med fortjeneste.og det er jo op til ens samvittighed. og jeg tror ikke der er ret mange i denne tråd der kan sige de aldrig har solgt noget med fortjeneste og måske til liodt overpris.
(permalink) Jan M181 Member
Ja lidt købmænd er vi vil alle, ellers ville der jo ikke være HBO !!
I´m drivning a legend
M181 1975
(permalink) mille Member
popcorn and cola is ready.. :-))
(permalink) niels-erik Member
Bare pas på hendrixx-om kort tid (hvis det ikke er sket) så kommer laila (eller hvad hun nu hedder) efter dig-he he.
Been there done that!
Boy, I could of saved you all alot of time, look at his name, pick up jens, so if you took anything else to him, it cant work, it has to be a pickup !! ;-) right ?
Or that is what the others told me ! hehehe
DISCLAIMER
I coty johnson confirm this is a joke. This joke is meant for educational purposes only. Any resemblance to real persons, living or dead is purely coincidental. Void where prohibited. Some assembly required. List each check separately by bank number. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Postage will be paid by addressee. Subject to CAB approval. This is not an offer to sell securities. Apply only to affected area. May be too intense for some viewers. Do not stamp. Use other side for additional listings. For recreational use only. Do not disturb. All models over 18 years of age. If condition persists, consult your physician. No user-serviceable parts inside. Freshest if eaten before date on carton. Subject to change without notice. Times approximate. Simulated picture. No postage necessary if mailed in the United States. Please remain seated until the ride has come to a complete stop. Breaking seal constitutes acceptance of agreement. For off-road use only. As seen on TV. One size fits all. Many suitcases look alike. Contains a substantial amount of non-tobacco ingredients. Colors may, in time, fade. We have sent the forms which seem right for you. Slippery when wet. For office use only. Not affiliated with the American Red Cross. Drop in any mailbox. Edited for television. Keep cool; process promptly. Post office will not deliver without postage. List was current at time of printing. Return to sender, no forwarding order on file, unable to forward. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. At participating locations only. Not the Beatles. Penalty for private use. See label for sequence. Substantial penalty for early withdrawal. Do not write below this line. Falling rock. Lost ticket pays maximum rate. Nap was here. Your canceled check is your receipt. Add toner. Place stamp here. Avoid contact with skin. Sanitized for your protection. Be sure each item is properly endorsed. Sign here without admitting guilt. Slightly higher west of the Mississippi. Employees and their families are not eligible. Beware of dog. Contestants have been briefed on some questions before the show. Limited time offer, call now to ensure prompt delivery. You must be present to win. No passes accepted for this engagement. No purchase necessary. Processed at location stamped in code at top of carton. Shading within a garment may occur. Use only in a well-ventilated area. Keep away from fire or flames. Replace with same type. Approved for veterans. Booths for two or more. Check here if tax deductible. Some equipment shown is optional. Price does not include taxes. No Canadian coins. Not recommended for children. Prerecorded for this time zone. Reproduction strictly prohibited. No solicitors. No alcohol, dogs or horses. No anchovies unless otherwise specified. Restaurant package, not for resale. List at least two alternate dates. First pull up, then pull down. Call toll free number before digging. Driver does not carry cash. Some of the trademarks mentioned in this product appear for identification purposes only. Objects in mirror may be closer than they appear. Record additional transactions on back of previous stub. Unix is a registered trademark of AT&T. Do not fold, spindle or mutilate. No transfers issued until the bus comes to a complete stop. Package sold by weight, not volume. Your mileage may vary. If the flow controls supplied are not installed, this unit will not operate properly. Keep out of reach of children. When this set is used with other equipment, if the picture is not stable or the buzz sound is heard, try to change the mutual position of relevant equipment or take enough distance between them. This unit not labeled for retail sale. Phenylketonurics: contains phenylalanine. Close cover before striking. Mind the gap. No merchantability expressed or implied. Parental discretion is advised. Sold as a novelty item only. Although robust enough for general use, adventures into the esoteric periphery may reveal unexpected quirks. Not available in stores. May cause abdominal cramping and loose stools. Vitamins A, D, E, and K have been added. Not designed or intended for use in on-line control of aircraft, air traffic, aircraft navigation or aircraft communications; or in the design, construction, operation or maintenance of any nuclear facility. Container may explode if heated. May contain traces of various nuts and seeds.
This supersedes all previous notices.
coty altså-fnis!
(permalink) Carsten Madsen, Slagelse Member
Indlægget hedder; skal du/har du handlet med pick-up jens??? Ja det skal jeg og ja, det har jeg, og jeg har altid været tilfreds. Jeg har hver gang vurderet varen før jeg handlede. Nu er der et par jyder der tilsyneladende har haft en dårlig oplevelse. Et lille fif, betal først varen når du henter. Det gælder generelt i alle handler, med alle mennesker.
Med hensyn til denne latterlige mudderkastning, så er det fint at brodne kar bliver fremhævet, men hvad jeg hører på vandrørene i denne sag, er at Hendrixx har en personlig vendetta mod Jens, og der er sgu lidt for nemt at hænge ham ud her. Ligesom Ekstra bladet, er det stort set gratis at hænge folk ud offentligt, og selvom det bliver modbevist, vil der altid være en mistanke om at der ikke kommer røg uden ild.
Jens er pisse dygtig med sine hænder, og når han går i gang sker der virkelig noget. At han så laver hurtige handler også, det bør du selv vurdere om du vil deltage i.
Denne tråd som bla. inddrager Jens´ udlejer som ikke er her på siden, og derfor ikke kan modbevise det der påstås, er for lavt. Du fik opsagt dit meget fordelagtige lejemål, se indad istedet for at give Jens, Laila, Tage og alle andre skylden for din egen opførsel, som førte til dette!!
Og nej, jeg har ikke noget i klemme hos Jens.
Den der siger sex er det bedste i verden, har aldrig været rigtig skidetrængende!
Clytzen@hotmail
Topic Closed
This topic has been closed to new replies.
