  drag race motor.
(permalink) bang Member
springer på noget vildere så derfor er min motor til salg.
alt er tip top og der er ikke sparet noget.
alt unødig snak frabedes hey. want to sell my type 1 2387 drag engine.
it has 20 runs on it and all parts where new.
build last spring with all the best parts.
type 1 alu case modifyed by geers for flange crank and roller cam.
86mm scat flanged crank. 8 bolt flyl with j&g floater clutch and plack magic disc.
pauter rods 5,6"
cp pistons with gasport.
geers roller cam. high rpm.
manton pushrods
autocraft 1,5 stage oilpump
geers alternator
pauter 1:1,5 rroller rockers.
ce heads modifyed by dave kawell with 46-40 valve and steel guide on the exhaust. k800 springs.
all balanced
full msd with box and coil.
setup to run c16
turbo setup is from m- spec
demon carburator, comp turbo, turbosmart gatevalve with eboost controll
ring om spørgsmål og pris.
22971295
tlf 22971295
http://cal-look.no/lounge/index.php/topic,15348.msg232458.html#msg232458
tlf 22971295
