  KØBES: 25 hk motor ufuldstændig
(permalink) ariedam Member
Hej stipendiater
Køb motor 25 hk har brug for hoveder stempler cylinder osv. Mine blev opgraderet brug for dele til at fuldføre. Nogen der har noget lignende i garagen? industrien er også ok, hvis er 25 hk.
Hello fellows
Buy engine 25 hp need heads pistons cylinder etc. Mine was upgraded need parts to complete. Anyone have something in the garage with this parts? industrial is also ok if is 25 hp
oldvwariedam@gmail.com
Thanks for the help
(permalink) Stefan1302 Member
Har en hel motor stående. ved ikke om den kan køre, drejer fint rundt.
Mvh Stefan
2895 1152
Hvad er livet uden luft!!! vand er kun til at blandee i drinks.
Hej Stefan godt at høre dig, lyt så send mig nogle billeder til min email, serielle og prisen for det:
Tak for svaret, mange tak igen for hjælpen.
Frank
(permalink) SJN Member
Lugter langt væk af google translate :-D
Med Venlig Hilsen
Søren Nielsen, Kolding
KGB Kolding Gear Boxers
Hello good evening.
True is google translate :D I don't speak Danish unfortunatly :( but I think that google translate doesnt translate very good:-S or I dont write good in english so must be both, I try what I can :)) Speak with Anders we could understand each other :))
Regards
Frank
(permalink) mccloud Member
Hy Claus cheers, thanks for the tag, listen send me the method payment to my email so I can begin to proceed with the transfer.
Let me know if is ok.
thanks again for the help
Frank
I am trying to work if I can find that part for the filter oil for you, Maybe I can find it here in Portugal who knows.
Stefen Hello again,
the google traslator is bad, so i let in english Stefen.
I asked pictures and details, serial etc maybe someone here can help me with this also, for example a correct translation :) errrhhh this is not easy.
Thanks again cheers.
Frank
Good day.
Claus you have email.
Thanks and best regards
Franklin
