  Engine parts...Vw type1
(permalink) RoadHog Member
Fk10 cam and followers used but good 800krs
Bolt on cam wheel 200krs
Melling oil pump 500krs
Twin port end castings for hiflow 400krs
Oil cooler 24 plate as new 400kr,
Msd ignition box as new in box...2500krs..
Standard clutch Sachs used..with two clutch discs 200mm 300krs
Tel 29385492...
Tel 29385492
Tel 29385492...Roskilda
(permalink) T.B Member
har du lidt mere info om Msd box ?
Solrød strand Tlf. 40304951
Hey T.B it's a Btm for using with turbo or compressor but other than that is just the same as a standard Msd box with hi power spark and ,rev control as I say all most as new,every thing you need instructions...works with a standard 009..if you need more info on the Msd box..let me know..
