19:06 jbl: Type 3
17:05 tobje1000: Tobje1000
  Motordele vw Type 1
All used vw type.1 Engine parts,CB 4340 chromol crank 82mm for vw rod,Scat I-Beam rods 5.4",Engle w125 Cam,Bolt-up Rocker set by Scat 1.1.1 with Rhino feet,Melling oil pump,Oil pump cover By Berg,Scat Deep Sump.Engine AS41 for 90.5mm and opend up for 82mm crank and tapped for full flow oil.Crank needs a grinding and the case needs a align bor after a spun bearing,crank has been tested for craks no problems.
Tel 29 38 54 92 or matvw74@cool.dk
(permalink) bang Member
what is the price for scat 5,4 rods and scat rocker 1:1
peb@vestas.com
tlf 22971295
600Kr for the Rods and 500Kr for the Rocker shaft set or there about
price for all
vw-clubfyn
Mail : vwmanden@gmail.com
Tlf : 28742739
About 4500Kr for the lot and some more parts to Chromoly Pushrods Deep sump a now 90.5 case is about 3500Kr and Crank by Cb about 4000kr you could make a big Engine for not to much $$$$ 1776cc or 2110cc or 2275cc with some work.
How much for the w125cam?
(permalink) Mark S Member
pump and cover?
Cam Engle 125 300kr melling oil pump 300kr pump cover 200kr
Tel 29 38 54 92
