  buggy fra 1968..
(permalink) DukeOfDenmark Member
Så er der kommet gang i ombygningen... Bilen er ved maler og sadelmager nu... Juhuu.. Og der er lige bestilt stumper hjem...
ACC-C10-5207ACC-C10-5207 - AA-PRODUCTS - 94MM X 69MM - 1914CC PISTON & CYLINDER - DESIGNED FOR BEETLE STYLE 1600CC BASED ENGINE - MACHINING REQUIRED (COMPLETE SET FOR 1 ENGINE) SHIPPING CHARGES APPLY
1US $169.95US $169.95
C18-1254C18-1254 - VW JOURNAL 5.4 INCH CHROMOLY FORGED I-BEAM CON-RODS W/180,000 PSI BOLTS - BEETLE STYLE PERFORMANCE ENGINE - SET OF 4
1US $129.95US $129.95
C13-16-9502C13-16-9502 - OFFROAD DUAL PORT TIN-CHR-PAIR
1US $36.95US $36.95
C13-4499-01C13-4499-01 - EMPI LOGO BUTTON SHIFTER- SHORT - 10 INCH O.A.L.- T-HANDLE-BEETLE / GHIA / T-3
1US $45.95US $45.95
ACC-C10-2565ACC-C10-2565 - COMPLETE CABLE SHORTENING KIT / CLUTCH / THROTTLE / E-BRAKE
1US $7.95US $7.95
C26-105-253C26-105-253 - SCALLOPED ALUMINUM CRANK PULLEY - ALL BEETLE STYLE 13-1600CC ENGINES
1US $35.95US $35.95
ACC-C10-5750-CHACC-C10-5750-CH - DELUXE CHROMED HIGH OUTPUT ALTERNATOR CONVERSION KIT - FOR ALL 12-1600CC BEETLE/GHIA STYLE ENGINES
[CHOOSE YOUR ALTERNATOR:85amp Chromed Alternator - China]1US $209.95US $209.95
^ ACC-C10-5415ACC-C10-5415 - 12V CHROME PULLEY - BEETLE 67-79 / GHIA 67-74 / BUS 67-71 / THING 73-74
1US $0.00US $0.00
^ ACC-C10-5774ACC-C10-5774 - CHROME ALTERNATOR / GENERATOR STAND - ALL 61-79 BEETLE STYLE ENGINES
1US $0.00US $0.00
^ ACC-C10-5785ACC-C10-5785 - CHROME GENERATOR STRAP - BEETLE 67-79 / GHIA 67-74 / BUS 67-71 / THING 73-74
1US $0.00US $0.00
^ C13-9056C13-9056 - 3 PIECE CHROME GENERATOR BACKING PLATE KIT - BEETLE 67-79 / GHIA 67-74 / BUS 67-71 / THING 73-74
1US $0.00US $0.00
^ VWC-111-903-131-AVWC-111-903-131-A - ALTERNATOR / GENERATOR BELT ADJUSTMENT SHIM EA - ALL BEETLE / GHIA / BUS 50-71 / TYPE 3 / THING - SOLD EACH
10US $0.00US $0.00
^ VWC-111-903-137-EVWC-111-903-137-E - ALTERNATOR BELT 11.3 X 912MM - BEETLE 73-79
1US $0.00US $0.00
^ VWC-043-903-023-AC85VWC-043-903-023-AC85 - NEW 85 AMP CHROMED ALTERNATOR - HIGH OUTPUT REPLACEMENT FOR BEETLE 73-79 / GHIA 73-74 (CUSTOM UPGRADE FOR 15-1600CC BEETLE STYLE ENGINE) - NON BOSCH
1US $0.00US $0.00
ACC-C10-3625ACC-C10-3625 - CHROME PEDAL COVER 3PC KIT - BEETLE 58-79 - GHIA 58-74 - TYPE 3 62-74 - THING 73-74
1US $9.95US $9.95
ACC-C10-5117ACC-C10-5117 - BOLT ON ALUMINUM VALVE COVERS - 12-1600CC BEETLE STYLE ENGINES - HARDWARE & GASKETS INCLUDED
1US $26.95US $26.95
C13-4484C13-4484 - EMPI - EMERGENCY BRAKE BOOT - WHITE - BEETLE 65-79 GHIA 65-74 TYPE 3 65-74
1US $5.95US $5.95
ACC-C10-3598ACC-C10-3598 - QUICK SHIFT KIT - CAST ALUMINUM - FOR STOCK SHIFTER - BEETLE - GHIA - TYPE 3 - BUS - THING
1US $4.75US $4.75
C21-1638C21-1638 - GERMAN DOUBLE LIP RED SILICONE FLYWHEEL SEAL (REAR MAIN) - ALL 40HP 12-1600CC BEETLE STYLE ENGINES
1US $8.95US $8.95
ACC-C10-5437ACC-C10-5437 - BILLET STYLE OIL DIPSTICK
1US $10.45US $10.45
ACC-C10-5626ACC-C10-5626 - BILLET FUEL PUMP BLOCK OFF
1US $12.95US $12.95
ACC-C10-1124ACC-C10-1124 - CHROME T-BARS FRONT OR REAR - PAIR - BEETLE 68-73
2US $16.95US $33.90
C13-8544C13-8544 - EMPI - ALUMINUM OIL BREATHER BOX KIT - W/EMPI LOGO - COMPLETE W/HARDWARE - ALL ENGINES
1US $28.95US $28.95
ACC-C10-5855ACC-C10-5855 - CHROME PLUG WIRE SEPARATOR KIT
1US $3.95US $3.95
ACC-C10-5695ACC-C10-5695 - CLEAR DISTRIBUTOR CAP - ALL 009 DISTRIBUTORS / BEETLE 70-79 / GHIA 70-74 / BUS 70-79 / VANAGON 80-84
1US $5.95US $5.95
C24-113-198-007-GERC24-113-198-007-GER - GENUINE ELRING BRAND - MADE IN GERMANY - ENGINE GASKET SET - 1300CC-1600CC AIRCOOLED ENGINES (FLYWHEEL SEAL SOLD SEP.)
1US $14.95US $14.95
C12-3520-12C12-3520-12 - 8MM BLUE MEGAVOLT IGNITION WIRE SET - BEETLE 46-79 / GHIA 56-74 / BUS 50-71
1US $21.95US $21.95
C15-20175C15-20175 - SCAT - NEW STYLE HI-PERFORMANCE ALUMINUM SPRING-LOADED PUSHROD TUBES - WITH DUAL O-RINGS DESIGN - SET OF 8 - ALL BEETLE STYLE 1600CC ENGINES
1US $59.95US $59.95
ACC-C10-5974ACC-C10-5974 - DELUXE HIGH CAPACITY OIL DEEP SUMP KIT - ADDS 1 1/2 QUARTS OF OIL 1600CC BEETLE STYLE ENGINES
1US $59.95US $59.95
C26-115-541C26-115-541 - POLISHED ALUMINUM ANGLED OIL FILLER WITH BILLET OIL CAP - BEETLE STYLE ENGINES
1US $23.70US $23.70
ACC-C10-9693ACC-C10-9693 - HOW TO HOT ROD VW ENGINES
1US $22.95US $22.95
ACC-C10-5399ACC-C10-5399 - CHROME OIL SUMP PLATE - ALL 40HP 12-1600cc BEETLE STYLE ENGINES
1US $5.95US $5.95
C26-141-002C26-141-002 - STANDARD METAL WOVEN CLUTCH DISC 200MM - 1600CC BEETLE STYLE ENGINES
1US $16.95US $16.95
ACC-C10-5386EACC-C10-5386E - INLET-OUTLET FULL FLOW OIL PUMP-13-1600 BUG STYLE ENG. 61-70 WITH FLAT STLYE (PERFORMANCE) CAMSHAFT - FITTINGS NOT INCLUDED
1US $49.95US $49.95
C13-9240C13-9240 - EMPI BRAND -CHROME OIL FILTER -FITS ALL FILTER PUMPS AND FILTER MOUNTING BRACKETS
1US $9.95US $9.95
C13-9204C13-9204 - OIL FILTER MOUNTING ADAPTOR BRACKET PORTS UP
1US $12
Det blev sgu en dyr omgang :-)
billederne ovenover er af hvordan den så ud inden maling og ny kabine..
(permalink) jannielsen Member
ok du har vist fået nogen dele hjem hehe men blir fedt at se når den er færdig :)
Og nice nick du har ;)
stakroge/herning email jangrabrielsen@live.dk
(permalink) Heide Member
hvor har du købt stumper? :)
cip1.. california imports..
Oki tak.. skri´ver di et indlæg når du får vareren hjem om kvali osv er ok :)
(permalink) berner100 Member
hvor meget måtte du betale for fragten?
320 us
SÅ er der bestilt maling hjem også.
Purple candy til at blande i lakken, sen skal først males sparkling siler basecoat. Og så have det purple candy over.. Glæder mig sgu til at se når den er sprøjtet..
Alt er købt ved http://www.mbscustompaints.com
Og lige vedhæftet et lille billede af farven :-)
Så er den lang om længe blevet malet :-)
Håber den når at bilve færdig til Bugrun..
(permalink) Blob Member
Rigtig flot farve.
Hvad er det for en fiks bette kort gearstang du har?
Jakob
Det er en oversavet original med momo gearknop :-)
Så er der også billeder fra sadelmageren.. Nu er den sgu ved at være færdig
(permalink) Hye Member
Nu vil jeg ikke være en festbremse, men vender din gearstang ikke forkert??
Hye
73´ 1303 Cab
73´ buggy
58´ Type 1
(permalink) Jens-Olebole Member
Din gearstang vender fejl vej..
Men ellers fed vogn!
Dare to be different
http://www.facebook.com/pages/Unneberg-Bil/258475930851176
Jo, det har i da helt ret i :-)
Den har sadelmageren vist lige fået vendt forkert.. Men pyt, jeg vender den da lige når den kommer retur..
Så er der nye billeder.
Og bilen kommer hjem tirsdag. Glæder mig sgu som et lille barn :-)
(permalink) Akke Member
Kan jeg squ godt forstå :-) Fint projekt!
vw Beach Buggy 1600
Jaguar xj6 4.2
(permalink) oye Member
Fin og flot, men hvad måtte du smide for at få den malet ?
så har bilen været hjemme noget tid, og jeg er stadig igang med at pusle med den.. Seneste problem er koblingen der ikke virker.. Se anden tråd...
Men her er de seneste villeder.
(permalink) SoLow Member
Bare lige for en sikkerheds skyld... nu er det ikke Thermowrap fra Thansen du har brugt vel.. det ligner ikke det rigtige som der er grafit i ?!?
Det fra Thansen har det med at antænde !!!
(permalink) Torben1500 Member
..og kan tilføje at jeg mener at dine luftfiltre er 'for korte'. Du bør indsætte et rør mellem karburator og filter på ca. 5 cm for ikke at risikere at få benzinsprøjt ud af igennem dine luftfiltre.
Hilsen
Torben
Hej torben, Tak for info, det vil jeg da få lavet.. Tager fat i farmer og hører hvad han har på hylden :-)
så er den kommet ud i den fri luft og blevet vasket.. MEN MEN MEN den skal sælges.. Den er sgu for lille til mig..
Jeg kan ikke rigtigt nå både speeder og bremse med højre foden :-( så bliver ´mine ben for lange og går på rattet..
(permalink) GiDenGas Member
Overvejet at ændre på hældningen på ratstammen istedet for at sælge den ? :o)
Roder med type 1 fra 68 og hedder sjovt nok Mads og er fra Kbh. Mobil 40 98 12 00
