  s:ny 2007ccm thick wall
du kan få min type 1 1959 værdi 65k
http://www.aircooled.dk
Er fra AA
(permalink) RoadHog Member
90,5 JE super thickwall all I can see is VW 92 X 82mm Thick Wall Kit Piston & Cylinder Kit at AA home page
This is a new set of 92mm VW Aircooled Thick Wall Type 1 Pistons and cylinders - These Cylinders are a full 2mm thicker than a standard 94mm cylinder. Perfect for those who want the ultimate in cooling or strength for High Performance applications. Fits 94mm cylinder case & 94mm heads.
Engine size: Stroker 2180cc
Stroke: 82mm stroker pistons
Cylinders: Cast Iron
Pistons: Hypereutectic aluminum alloy
Compression Height: 35mm
Kit includes: 4 Cylinders, 4 Pistons, 1 set of Piston Rings and 4 Pins and clips.
Machine Work Required
Part # VW9200T1MS
Is AA as good as Cima/Mahle or JE...Only ever used Cima/Mahle ones never had problems,old 92s no good
(permalink) dannykok Member
hvad er prisen på motoren nu??
og kan den evt monteres i en buggy??
Er fra AA
(permalink) Roadrunner Member
Hvilke motorer drejer det sig om?
Er fra AA
motoren er stadigvæk til salg
pris 48000kr med ny udstødning csp. dette er ca 30k under den pris det ville koste hvis du skulle lave en magen idag
